[OpenFOAM] pointVectorField in ParaFoam
Old   April 22, 2010, 08:36
Default pointVectorField in ParaFoam
Silvan Brändli
s_braendli is on a distinguished road
Hallo everybody
Trying to visualize pointVectorFields with ParaFoam I'm meeting some problems:
A point vector field can't be loaded on a mesh, only on patches (else ParaFoam crashes -> XXX/bin/paraFoam: line 83: 13992 Segmentation fault paraview --data=$caseFile )
So I try to load the pointVectorFields with only patches chosen in "regionstatus". pVF "A" only contains (nonzero) data on its boundary. paraFoam doesn't recognize any nonzero data. "Information" -> "Data ranges" also shows, that the field only contains zeros.
pVF "B" contains data in the internal Field and at its boundary. It is displayed correctly.
When I manually copy B's internal Field to A, A shows the same as B, although its boundary is different and I only want to show the data on patches.
My guess about what is happening: In order to show data of pVFs on patches, ParaFoam uses the data of the internal Field instead of the boundary.
Has anybody experienced a similar problem and/or can give any hint on how to visualize the data saved in the boundary of a pVF?
Any help would be appreciated
Silvan
s_braendli is offline   Reply With Quote
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 5 March 23, 2022 08:09
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 17:03
[OpenFOAM] How to use paraFoam on a cluster andreas ParaView 1 March 6, 2013 17:11
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
[OpenFOAM] ParaFoam OF 14 decomposed cases philippose ParaView 4 April 18, 2007 05:17
