Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] View grid coordinates in Paraview
Like Tree1Likes
  • 1 Post By ozzythewise
Old   June 30, 2010, 10:54
Default View grid coordinates in Paraview
jeff osborne
ozzythewise is on a distinguished road
Hi all,
I would like to see grid coordinates in paraview as I am trying to make some contour plots and it would be great to see at what x and y coordinates correspond to what feature in my solution. Any body know how I can get paraview to display the grid coordinates?
Thanks
-J
ozzythewise is offline   Reply With Quote
Old   June 30, 2010, 11:04
jeff osborne
Nevermind, I found the solution about 2 minutes after I posted. For all those interested you click "Show cube axes" in the display tab.
Follow-up question, how do I change the font size of the cube axis as well as the distance between tics? There doesn't seem to be those options in the "Edit" tab.
Antony_Bosco likes this.
Old   May 31, 2017, 13:49
Default can''t display cube axes length scale properly
MUGET
paramu is on a distinguished road
after several weeks of trying on different versions of paraview, 5.0 5.1 and 5.2, i have become completely desperate to plot the length scale on the origin FRONT position of my figures. I only manage this on version 5.0 on my laptop, but then loading 5.0 on my workstation doesn't enable me to show them either! This is really really really strange.
I don't get to display the Cube Axes "famous" button on my properties panel.
I just get the "Axes grid" option, and when i want to Edit it, i can't get a handle on the frontface culling, and then even when i do (i did manage 2 times), it didn't work out either. The best i get is plotting the axes scales in the back faces of my 3D figure (as attached figure), which is of no use because i need to zoom in my figure a lot so that they get out of the image.. argh...
My feeling is that i must have an option switched on or off somewhere that avoids showing the "cube axes" option.. but afte rlooking and looking, i am hopeless... please, anyone with a clue ??? I would be very greatful... thank you in advance.. Mupara
paramu is offline   Reply With Quote
Old   June 6, 2017, 04:12
Default solution
MUGET
actually a colleagu and i finally found the answer,
so for those who might have had the same issue....
actually in the axes grid/edit window, when neither the culling options nor the Label axes appear, the solution is to type in the search menu the key words:
- first "culling", so that one can choose indeed between frontface and backface culling,
- second "label", so that one can unclick the "Label unique axes only" option and choose which axes and which ticks to display.
bye, MG.
How to use UDF to get a grid cell centroid coordinates? lvanlee FLUENT 4 December 20, 2021 06:55
[OpenFOAM] view OpenFOAM result in ParaView on another machine base0 ParaView 0 November 12, 2015 19:29
[OpenFOAM] Can I view the files I got from the CFX-solver in Paraview? sparlund ParaView 1 March 17, 2014 11:19
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
