Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Render result on geometry in ParaView.
Old   February 5, 2011, 08:00
Question Render result on geometry in ParaView.
Bylund is on a distinguished road
This is my first post here at cfd-online, I hope I do it correctly.
I tried just for fun to make a primitive wind tunnel case which is basically just a cylinder with an extracted geometry (Sphere).
I can import the Sphere geometry from STL in ParaView. But how do I render the result (p for example) on the STL?
Example from Ansys:
(I tried to search with no results, here nor google)
Thank you,
Christian
Mechanical Engineer
Bylund is offline   Reply With Quote
Old   February 12, 2011, 07:12
I have seemed to somewhat solved my problem.
This is how I did:
  • I created a geometry group in Salome for the evaluated geometry.
  • In paraview I select only this geometry in 'Mesh Region'.
  • I can also load more then one instance of the foam case to combine with a nice stream tracer.
Maybe someone else could benefit from this.
Mechanical Engineer
paraview, render, results, visualization
Error: Operation would result in Non-Mainfold geometry fergal ANSYS Meshing & Geometry 1 December 9, 2013 08:04
solidDisplacementFoam - problem with weakly nonsymmetric result on symmetric geometry Sergejevicz OpenFOAM Running, Solving & CFD 0 October 3, 2012 13:20
[snappyHexMesh] Meshing geometry not visible in paraView. Nikunj.R OpenFOAM Meshing & Mesh Conversion 4 October 2, 2012 15:45
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
