Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview chrashed by using "plot over line"
Old   November 15, 2011, 06:59
Default Paraview chrashed by using "plot over line"
Stefan
preibie is on a distinguished road
Hallo
I have a little Problem with paraview 3.10. When I want to use the filter "plot over line" paraview stopped and the following massage is on the shell.
X Error: BadLength (poly request too large or internal Xlib length error) 16
  Extension:    135 (Uknown extension)
  Minor opcode: 1 (Unknown request)
  Resource id:  0x3803ec3
libxcb: WARNING! Program tries to lock an already locked connection,
        which indicates a programming error.
        There will be no further warnings about this issue.
I use paraview via ssh.
Preibie
preibie is offline   Reply With Quote
Old   November 15, 2011, 07:57
Olivier
olivierG is on a distinguished road
hello,
Paraview doesn't work well in ssh -X, VNC or NX distant connection, specialy with "plot over lines" and some other function.
You may try to mount the distant dir via sshfs and run paraview directly on your pc, or use paraview in remote configuration.
regards,
olivier
olivierG is offline   Reply With Quote
Old   November 15, 2011, 08:30
Stefan
thanks for the fast help. You say that it is possible to run paraview in remote configuration. How I can do this?
Old   November 15, 2011, 09:00
Olivier
hello,
take a look at http://www.itk.org/Wiki/Users_Guide_..._Visualization and http://www.itk.org/Wiki/ParaView/Use...rallel_Servers
If you use an ssh acces on non local network, you may use ssh port forwarding.
Regards,
olivier
Old   November 18, 2011, 03:50
Stefan
this was a very good idea! Now I can use plot over line
Thanks Preibie
[OpenFOAM] Plot over line average magnitude of particle velocity in paraview maysmech ParaView 13 August 12, 2022 11:46
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
