Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Fit the image using run time post processing
Old   February 19, 2019, 06:45
Default Fit the image using run time post processing
Gaubtas is on a distinguished road
Hi I am using run-time post processing to get a nicely generated image after my OpenFOAM case is done. I do this as a part of automating the CFD process. The part I am stuck on is scaling the result to fit the image.
controlDict contains camera section which adjusts what I'm looking for.
camera {
nFrameTotal 1;
zoom _zoom; //replaced at runtime by a script, but how do I compute this?
parallelProjection yes;
position (_halfWidth, _halfHeight, 1); //center the view
focalPoint (_halfWidth, _halfHeight, 0); //center the view
clipBox (0,0,0)(_width, _height, 1);
The cases are essentially 2d. Problem for me is that I want to fit the image to the entire resolution. There is some kind of correlation between this and the aspect ratio of the simulation (setting zoom to be aspect ratio almost works). I can't figure out why or what is the exact behaviour. Ideally I would like some padding on the right side and put my scale legend there.
Coming from a 3D background I would imagine that you'd need to define a projection plane for a parallel (ortho) projection, but it seems the only parameter that does something similar is zoom, which seems arbitrary.
Gaubtas is offline   Reply With Quote
Old   February 20, 2019, 09:31
Seems I've found a solution.
Ended up using:
camera
viewAngle 90;
nFrameTotal 1;
parallelProjection no;
focalPoint (_halfWidth _halfHeight 0.0);
up (0 1 0);
position (_halfWidth _halfHeight _offsetHalfHeight);
for _offsetHalfHeight (distance away from the mesh):
If your mesh has 0 depth, or all depth is in -z coordinated (front face is z 0) then you can use half of the height of the simulation space. If it is not you have to add half of the depth of the mesh to half of the height of the mesh.
Still not sure how parallelProjection behaves.
Old   August 7, 2019, 08:38
Carlo_P
Carlo_P is on a distinguished road
Hey Gaubtas,
I'm managing to understand how to create pics in openFOAM.
can you give me the controlDict file?
Thanks a lot,
Carlo
Carlo_P is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 22:29
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
time averaged solution in post processing coolwave Fidelity CFD 0 September 4, 2015 08:29
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
