Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Weird aerodynamic forces on 3D body.
Old   June 12, 2020, 07:43
Default Weird aerodynamic forces on 3D body.
Aurora
Ducagirl is on a distinguished road
Hello everyone!
I am quite newbie with OpenFoam and I am doing an aerodynamic laminar simulation around a .STL file. The results for p and U seem pretty good, but now I have tried to calculate forces and coefficients and the look quite inconsistent.
The objetc is a mount situated in the top of a yatch (only air influence), and I have recreated some damages into the surface in order to compare the different levels of injuries.
I attatch the screenshot of my results after 500 iterations, and also the controlDict script and functions it uses:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 500;
deltaT 1;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
#include "forceCoeffs"
#include "forces"
#includeFunc residuals
\\/ M anipulation |
forces
type forces;
libs ("libforces.so");
timeInterval 1;
log yes;
patches (soporte);
rho rhoInf; // Indicates incompressible
log true;
rhoInf 1; // Redundant for incompressible
CofR (0 0 0); // Rotation around centre line of propeller
pitchAxis (0 0 1);
\\/ M anipulation |
forceCoeffs
type forceCoeffs;
timeInterval 1;
log yes;
patches (soporte);
liftDir (0 1 0);
dragDir (1 0 0);
CofR (0 0 0); // Axle midpoint on ground
pitchAxis (0 0 1);
magUInf 13;
lRef 0.6; // Wheelbase length
Aref 0.617; // Estimated
binData
nBin 20; // output data into 20 bins
direction (1 0 0); // bin direction
cumulative yes;
Thank you for your help!
Aurora.
File Type: jpg Captura de pantalla 2020-06-12 a las 13.25.31.jpg (152.4 KB, 3 views)
Ducagirl is offline   Reply With Quote
Enabling body forces (gravity) asonda SU2 1 February 21, 2018 10:42
Ahmed body: questions about reference area and forces sandyy235 OpenFOAM 4 October 30, 2016 08:50
UDF for Body Forces in DPM Shalabh Fluent UDF and Scheme Programming 0 June 23, 2016 16:39
body forces, moving mesh researcher Main CFD Forum 0 March 26, 2016 01:15
Aerodynamic Forces on Periodic Walls in Fluent Hybrid FLUENT 0 October 13, 2015 21:48
