Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
outputting averaged quantities to a text file in parallel execution
Old   January 31, 2013, 17:08
Default outputting averaged quantities to a text file in parallel execution
Jace
zhengzh5 is on a distinguished road
I am currently working with OpenFOAM-2.0.x, and trying to do some engine simulations. I want to calculate average quantities such as meanPressure, meanTemperature at every time step and output them to, say, summaryLog file.
In serial execution, I have
totalV = sum(mesh.V().field());
sumMass = fvc::domainIntegrate(rho).value();
pPistonMean = fvc::domainIntegrate(p).value()/totalV;
aveT = fvc::domainIntegrate(rho*Tu).value()/sumMass;
summaryLog << pPistonMean << " "<<aveT <<endl;
and things seem to work fine. But when I try to run the code in parallel with 4 processors, the output doesn't make sense to me anymore.
For instance, all 4 summaryLog files (1 per processor) will show the same sumMass when the mass contained in each decomposed domain should be different since the domain size varies a lot between processors. (I use scotch for domain decomposition) My questions are:
1. if each processor stores their own copy of mesh and internal fields such as, pressure, temperature, density.
2. when writing data to a text file, does each processor output the individual data it's holding, or does a certain processor does the task for all 4 processors.
Any help is appreciated. thanks a lot!
J.
zhengzh5 is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
