Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Vorticity Contour
Like Tree2Likes
  • 1 Post By VSass
  • 1 Post By VSass
Old   March 12, 2013, 05:57
Default Vorticity Contour
VS
VSass is on a distinguished road
Hey Foamers,
i've used the vorticity utility to calculate the vorticuty of my flow but i don't know how to plot it in Paraview. Is there any way except the stream tracer->coloured by : vorticity?
Thanks
VSass is offline   Reply With Quote
Old   May 29, 2013, 11:07
Default hello
WangJunlei
just4pipi is on a distinguished road
you can directly choose the viarible Vorticity in the board in Paraview.It's besides the P.U.
pipi
just4pipi is offline   Reply With Quote
Old   May 29, 2013, 14:56
VS
Thanks! After weeks i found out that you must first select it from the fields menu below "mesh parts".
thanks anyway!
louisgag likes this.
Old   May 30, 2013, 03:24
Default About the displacement
WangJunlei
vSass:
Do you know how to extract or compute the displacement of a plate moving in a flow field? I am trying a FSI problem,but I can't get it.
p1p1
Old   May 30, 2013, 03:47
VS
I have a little experience with FSI problems using OpenFoam.
Which solver are you using?
Old   June 2, 2013, 02:10
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
whats a FSI problem?what does it stands for?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 2, 2013, 07:16
VS
It stands for flow-structure-interaction, and it's about calculating stresses and displacements of the structure due to the presence of the flow.
Old   July 1, 2013, 12:41
Ehsan
Hi Vasileios
how do you define vorticity in 0 folder?
my case gives an error on it.
Time = 0.00027
    Reading U
    Calculating vorticity
vorticity max/min : 6832530.652 0.1754425241
End
Time = 0.000271
    Reading U
vorticity max/min : 6886705.616 0.1203675751
End
Time = 0.000272
    Reading U
vorticity max/min : 6860999.599 0.1231681867
End
Time = 0.000273
    Reading U
vorticity max/min : 6779457.723 0.1109132494
End
Time = 0.000274
    Reading U
vorticity max/min : 6905465.041 0.03421409343
End
Time = 0.000275
    Reading U
vorticity max/min : 7015169.336 0.2944563456
End
Time = 0.000276
    Reading U
vorticity max/min : 7120398.407 0.1211598064
End
ehsan@Ehsan-com:~/Desktop/WR$ paraFoam
created temporary 'WR.OpenFOAM'
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'T0_4=973;' on line 16 and ending at line 65"
file: /home/ehsan/Desktop/WR/0/include/variables_R at line 65.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file lnInclude/IOerror.C at line 132.
FOAM exiting
Old   July 2, 2013, 08:07
VS
Well, you don't need to define it yourself. What is your doubt about?
Old   July 2, 2013, 09:42
Ehsan
that's OK now.how can improve the quality of contoour shapes?they have too contrast from blue to red.do you change the range in paraview?till what value?
Old   July 2, 2013, 10:10
VS
Maybe the number of colours that you choose for your presentation can fix the problem. I use 17 colours. You can adjust them by clicking on the "Edit Colour Map" button.
immortality likes this.
Old   July 2, 2013, 11:02
Ehsan
that's very better now.I confined its range scal to [-20000,200000] and 17 colors as you said.
Old   March 19, 2019, 07:54
Default hello just4pipi
  #13
popa is on a distinguished road
Originally Posted by just4pipi View Post
vSass:
p1p1
Did you solve it?Now i meet the same problem,and i use icoFsiElasticNonLinULSolidFoam to solve FSI,if possible ,please leave your email,i think we are the same country.
Thank you.
popa is offline   Reply With Quote
paraview, post procesing, utilities, vorticity
How to Contour plot for omega_z ?? snehal OpenFOAM 3 March 11, 2017 05:41
[GAMBIT] Plotting/Meshing a Contour Map (3D hill) VU_Engineer ANSYS Meshing & Geometry 6 January 28, 2014 06:59
Vorticity Contour maysmech OpenFOAM 3 November 14, 2013 10:40
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
Vorticity Iso-Surface John Main CFD Forum 0 April 4, 2009 23:10
