Lack of RAM to visualize a big mesh. How can I do? |
March 21, 2013, 03:33 |
Samuele Z
Rep Power: 18 |
Dear All,
I have a big mesh 12.5M cells and I have performed a simulation (using simpleFoam first and then adjointShapeOptimizationFoam). Everything seems to be ok, until when I try to visualize my data. Because of a lack of memory, paraview crashes. Is there a way to visualize such a big field of results? Thanks a lot, Samuele |
March 21, 2013, 03:42 |
Anton Kidess
Rep Power: 30 |
Do you really need to see the whole domain? Either just look at a subset without reconstructing, or create some slices beforehand using the sample utility.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
March 21, 2013, 03:51 |
Samuele Z
Rep Power: 18 |
Actually, visualizing the whole domain would be the best way. Isn't there a way to see the domain in low-definition?
If this is not possible, I'll use a workaround with sets. Thanks a lot, Samuelel |
March 21, 2013, 04:06 |
Anton Kidess
Rep Power: 30 |
You could indeed make a coarser mesh, and then use mapFields to project your solution on the coarse mesh.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. Last edited by akidess; March 21, 2013 at 04:07. Reason: Language, spelling |
March 21, 2013, 04:09 |
Samuele Z
Rep Power: 18 |
This is a great idea, but just for visualization, at the end.
But I need some calculations, first (e.g. I have to evaluate a certain function on a surface and I can not use a coarse mesh). Anyway, this is a great advice I'll use for the final visualizations. Thanks a lot |
March 24, 2013, 06:39 |
#6 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- have you tried both readers (the built-in one as well) - Before clicking the button that actually loads the case have you tried deselecting all fields except one (or even deseleceting all to see if at least the mesh fits into memory) - the "para" in Paraview stands for "parallel". It's a long time since I done it, but if I remember it correctly you've got to start pvserver (not paraview) in parallel and then start paraview regularly and "Connect" to the pvserver. Google around there are presentations about this Quote:
Anyway: for quantitative analysis I'd prefer an option that is built only on OF to Paraview. Not because paraView is bad, but because it does its own interpolation, triangulation etc. With OF-native solutions (that includes swak) you use the values "as the OpenFOAM-solver saw them"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
