[swak4Foam] expressionSource problem
Old   May 3, 2013, 08:55
Default expressionSource problem
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
I am trying to use expressionSource, when I compile with wmake it says: (I am using openFoam 2.1). Don't have any idea why it happens....
SOURCE=interFoamWithSources.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam210/src/transportModels -I/opt/openfoam210/src/transportModels/incompressible/lnInclude -I/opt/openfoam210/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam210/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam210/src/finiteVolume/lnInclude -I../../../Libraries/swak4FoamParsers/lnInclude/ -I../../../Libraries/swakSourceFields/lnInclude/ -IlnInclude -I. -I/opt/openfoam210/src/OpenFOAM/lnInclude -I/opt/openfoam210/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/interFoamWithSources.o
interFoamWithSources.C:48:30: fatal error: expressionSource.H: No such file or directory
compilation terminated.
make: *** [Make/linuxGccDPOpt/interFoamWithSources.o] Error 1
ahmmedshakil is offline   Reply With Quote
Old   May 4, 2013, 07:08
Assistant Moderator
Bernhard Gschaider
Originally Posted by ahmmedshakil View Post
Did you copy the sources to a different location? Because the relative paths for some includes (-I../../../Libraries/ ...) assume that it is in a very specific location. If you did then you'll have to adapt these paths
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 4, 2013, 11:57
I have solved it, and this is due to the path. Thanks
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
