Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to output the Nusselt number
Old   May 7, 2013, 05:12
Default How to output the Nusselt number
刘朝福
liuchaofu is on a distinguished road
I calculate a jet cooling problems use Openfoam,Then I use the Tecplot post-processing,But I can't output the Nusselt number,or the heat transfer coefficient。Who can help me?
liuchaofu is offline   Reply With Quote
Old   May 7, 2013, 07:56
T. Chourushi
Tushar@cfd is on a distinguished road
Well, you can output the variable using utility, please refer the following link for more information...
http://www.cfd-online.com/Forums/ope...timesteps.html
Tushar@cfd is offline   Reply With Quote
Old   May 8, 2013, 09:26
刘朝福
Thank you for your reply.Because I am a newbie on OpenFoam,I only can output the temperature and speed using Tecplot.Can you tell me what variables wo should output to get Nusselt number and the methods.Thank you .
Old   May 8, 2013, 09:33
刘朝福
I have to OpenFoam version 2.1.1. I want to use the wall heat flux function.But when I enter this command.It shows this function could not be found.How should I set.Because I is the isothermal wall condition.I need to output the wall heat flux to calculate heat transfer coefficient
Old   May 8, 2013, 09:44
T. Chourushi
In the weblink:
Check this code:
volScalarField gradT ( IOobject ( "gradT", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector ( "gradT", T.dimensions()/dimLength, 0 ) ); label patchi = mesh.boundaryMesh().findPatchID("myPatch"); gradT.boundaryField()[patchi]=T.boundaryField()[patchi].snGrad(); runTime.write();
This is similar to the $utility/Postprocessing/wall/wallGradU file.
Copy this file and make new wallGradT file.
You need to put T instead of U, as mentioned above. Then try to compile the same. After you finish with this, run the utility in the case folder.
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Nusselt number 4.36 validation in a tube in constant heat flux situation QustFelix FLUENT 6 June 18, 2015 22:09
there is a problem with fully developed Nusselt number eeman Fluent UDF and Scheme Programming 4 September 24, 2012 01:36
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
