how to output the value along a certain line or on a plane |
April 20, 2016, 10:11 |
Shizuo Fu
Rep Power: 10 |
Hello, everyone,
I am a beginner to OpenFoam. I wonder if I can use paraview to output the value along a certain line and on a certain plane, instead of only displaying the data on the paraview interface. And I want to know the position vector of the cell corresponding to the output value. If paraview can not resolve this, is there any other software solving this problem? Thank you in advance! |
April 26, 2016, 00:41 |
Rep Power: 15 |
You can get value over a line or a plane using the sample utility. Check the User guide and tutorials where a sampleDict file is included. The location of a cell can be written into the time directory with the writeCellCentres utility.These files can be also used by the sample utility.
April 26, 2016, 07:41 |
Thank you, Bazinga.
Shizuo Fu
Rep Power: 10 |
Thank you, Bazinga. I tried the utility and found it solved my problem perfectly.
[Gmsh] No cells read from file ".msh" | hwsv07 | OpenFOAM Meshing & Mesh Conversion | 5 | August 13, 2018 15:42 |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 06:44 |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 10:31 |
[Gmsh] Conversion Error | nuovodna | OpenFOAM Meshing & Mesh Conversion | 14 | October 1, 2010 11:07 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
