December 5, 2015, 22:49 |
High drag coefficient Cd values
#1 | |
Rep Power: 10 |
I've run my simulations and I want to extract the Cd values for my cylinder.
1) I added the following function block in my controlDict (same template which I found online). Quote:
3) I took the average of all the values and I am getting Cd values in the range of 16-20. May I know what is wrong? Or that shouldn't be the way I should be doing. Are there parameters I should change in the forceCoeffs block that are specific to the case that I am running? HELP! |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
airfoil lift and drag coefficient | amir_14 | FLUENT | 5 | January 1, 2013 08:30 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
