[OpenFOAM] Colouring different decomposed mesh regions in paraview |
January 29, 2015, 17:44 |
Yuanchuan Liu
Rep Power: 13 |
I am just wondering if paraview is able to colour different mesh regions in a decomposed case. For example, the mesh region in processor0 is red and that in processor1 is blue, etc. Just like this image in OpenFOAM website introducing ami using a propeller: It seems very cool |
February 2, 2015, 07:10 |
Yuanchuan Liu
Rep Power: 13 |
I have found a way myself.
1. Create a *.foam file inside every processor folder, e.g., processor0.foam in processor0 and processor1.foam in processor1 etc. 2. Open paraview and load each foam file into it. 3. Now you can colour every piece of the decomposed mesh using the coloring feature. Hope someone likes it. |
January 3, 2019, 12:00 |
So Anon
Rep Power: 11 |
hello,
i am also trying to do the same thing. i can load a *.foam file in paraview in decomposed state. is there any way of coloring each processor's block differently? if not, is there an easy way of loading each processor*/*.foam file at once? like a script or something? thanks |
January 8, 2019, 04:04 |
anonymous
Rep Power: 14 |
Hi!
Try to use "decomposePar -cellDist" This will write the cell distribution as a labelList. So if you open the reconstructed mesh (NOT THE DECOMPOSED!!), there will be a cellDist field which will indicate the proc number for every cell. |
May 31, 2019, 02:26 |
Rep Power: 7 |
Hey there,
I had the same issue so I wrote a small utility that can be run in parallel on a decomposed case. It writes the procID as new field in the processor/time directories. The field can be reconstructed and visualized in paraview. Small changes may be needed as I am using OFv1612. Cheers RP |
May 31, 2019, 04:55 |
Thanks for sharing. Simple and useful. I got it running as is on OF-6-dev.
-Louis PS: I've made a few changes to compile on v1812, did not dig into the explanations for them but it compiles and runs properly, see attached patch files. Last edited by louisgag; May 31, 2019 at 07:30. |
Moving mesh - Multiple Regions | user10600 | OpenFOAM Programming & Development | 1 | December 10, 2015 05:01 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
ParaView shows blocky mesh | lfbarcelo | OpenFOAM | 3 | June 25, 2010 08:16 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
