Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Shell script to handle Segmentation faults arising from execFlowFunctionObjects
Prev Previous Post   Next Post Next
Old   February 22, 2015, 14:20
Lightbulb Shell script to handle Segmentation faults arising from execFlowFunctionObjects
Pruthvi
pruthvi1991 is on a distinguished road
Hello foamers!
I frequently face segmentation faults and corrupted double linked list errors when using execFlowFunctionObjects for post processing. I get this error when I run cases with pmpleDyMFoam solver.
As a work around for this problem I wrote a simple shell script which will find out the time at which execFlowFunctionObjects crashed and makes it restart from that point. This is not an elegant way of fixing the problem but it works
The code is on github
#!/bin/bash
echo "This script will call execFlowFunctionObjects to integrate the pressure and viscous forces over the chosen patches.
This function may take a few minutes to execute, please be patient. Make sure you entered the desired function object
in system/controlDict. For Eg: #include "forceCoeffs" . If the function is commented this script will not work"
sleep 2
echo "Deleting log files from previous runs. You have 8 seconds to abort by holding ctrl-c"
sleep 8
#mkdir previous_data
rm log.forces # ./previous_data/
rm -r postProcessing # ./previous_data/
endTime=$(grep -w 'endTime' ./system/controlDict | grep '[0-9]' | sed 's/;//g' | awk '{print$2}')	# Gets endTime value from controlDict
intendTime=$(grep -w 'endTime' ./system/controlDict | grep '[0-9]' | sed 's/;//g' | awk '{print$2*1000}')       # Multiplying by 1000 to convert to integer in case endTime is float
writeTime=$(grep -w 'writeInterval' ./system/controlDict | grep '[0-9]' | sed 's/;//g' | awk '{print$2}') # Gets writeInterval from controlDict
execFlowFunctionObjects >> log.forces &		# Executes the function execFlowFunctionObjects and writes output to log.forces
sleep 15	# If there is no sleep time, bash proceeds to the next command before execFlowFunctionObjects is run. Increase this if your simulation is large
presentTime=$(tail -22 log.forces | grep Time | awk '{print$3}' | awk NR==1)	# Checks for many time steps the function ran and gets the last time value
intpresentTime=$(tail -22 log.forces | grep Time | awk '{print$3*1000}' | awk NR==1)	# Converting a possible float to integer
echo "endTime = $endTime, presentTime = $presentTime, Integer endTime = $intendTime, Integer presentTime = $intpresentTime, writeInterval = $writeTime"
echo "Entering Loop at $presentTime"
while [ $intpresentTime -lt $intendTime ];		# If the function failed to execute at some point this loop will make it start again
do
#	startTime=$(python -c print " $presentTime + $writeTime ")  # Finds time from which the function must start again
	startTime=$(echo "$presentTime+$writeTime" | bc)  # Finds time from which the function must start again
	echo "Crashed at $presentTime, re-starting from $startTime"
	execFlowFunctionObjects -time $startTime: >> log.forces &
	sleep 10	# Waits for 15 seconds before executing next command. This is necessary to ensure execFlowFunctionObjects is not re-run midway
	echo $presentTime
done
echo "Finally reached $presentTime"
After the script is run, numerous force/ forceCoeffs files will be generated in the postProcessing directory. I wrote another script to merge them together and parse the data. Here is the github link.
Thanks,
Pruthvi.
pruthvi1991 is offline   Reply With Quote
corrupted list, execflowfunctionobjects, pimpledymfoam, post procesing, segmentation fault
OF-2.3.x: Get "latestTime" in a shell script? A_Pete OpenFOAM Programming & Development 4 September 29, 2020 04:19
paraView in shell mode (python script running) Prosiaczek OpenFOAM 2 March 19, 2012 07:54
