Result of forces-Object on multi Machines wont write to file
Old   August 5, 2015, 04:30
Default Result of forces-Object on multi Machines wont write to file
Sway is on a distinguished road
hejhej,
i need the forces on a specific patch and therefor i use the function forces. it works fine when running on a single machine, but on cluster it stops writing the results to the forces file in /postProcessing/forces/ but the Terminal output still works
can someone please help me on this issue?
my controlDict:
|  \\    /   O peration     | Version:  2.4.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
libs
    "libOpenFOAM.so"
    "libincompressibleTurbulenceModel.so"
    "libincompressibleRASModels.so"
    "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
application     pimpleFoam;
//startFrom       latestTime;
startFrom      startTime;
startTime       0.89953;
stopAt          endTime;
//stopAt writeNow;
endTime         10;
deltaT          0.001;
writeControl    adjustableRunTime;
writeInterval   0.05;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           0.2; //0.2
functions
 forces
    type        forces;
    functionObjectLibs ( "libforces.so" );
    outputControl timeStep;
    outputInterval 1;
     patches     ( mypatchname );
     pName       p;
     UName       U;
     rhoName     rhoInf;      // Indicates incompressible
     log         true;
     rhoInf      1000;           // Redundant for incompressible
     liftDir     (0 1 0);
    dragDir     (1 0 0);
    CofR        (0 0 0);  // Axle midpoint on ground
//     pitchAxis   (0 1 0);
 //    magUInf     3;
//     lRef        1.42;        // Wheelbase length
//     Aref        0.75;        // Estimated
    massFlow
       type patchMassFlow;
       functionObjectLibs
           "libsimpleFunctionObjects.so"
       verbose true;
       patches
           inlet
           outlet
       factor 1;
       outputControlMode timeStep;
       outputInterval 1;
   pressureDrop
        type patchExpression;
        variables (
            "pOut{patch'outlet}=sum(p*area())/sum(area());"
            "inArea=sum(area());"
        accumulations (
           sum
        patches (
            inlet
            outlet
        expression "area()*(p-pOut)/inArea";
        verbose true;
       outputInterval 1;
Sway is offline   Reply With Quote
Old   September 2, 2015, 09:45
the answer to this problem was the umask of the slave-machines. the data they wrote wasnt readable by the master-computer. i changed it to 000 globaly on all slaves
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
