[swak4Foam] weighted average over a subset of a planar slice?
Old   March 14, 2016, 09:30
Default weighted average over a subset of a planar slice?
Pete Bachant
pbachant is on a distinguished road
I have a case setup to use swak4Foam to compute some weighted averages over a slice of my domain, but I would really not like to use the entire cross-section, since my experiments don't reach that far. Right now I'm using something like this with funkyDoCalc:
planeAverageAdvectionZ
    type swakExpression;
    outputControlMode timeStep;
    outputInterval 1;
    valueType surface;
    surfaceName testPlane;
    surface {
        type plane;
        basePoint (1.0 0.0 0.0);
        normalVector (1 0 0);
        interpolate true;
    verbose true;
    expression "-UMean.z/UMean.x*gradUMeanX.z";
    accumulations (weightedAverage);
But I would like to change testPlane to only extend, e.g., from (1 -1.5 0) to (1 1.5 0.625) min/max points, with the same normalVector. Is there an appropriate syntax to do this, or do I need to create a cellSet or something and only compute within that?
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   March 21, 2016, 03:29
Silvan
silvan is on a distinguished road
dear pete,
thanks for posting your issue. it is an interesting task, and I tried to achieve something similar in the past with topoSet. my post is here: http://www.cfd-online.com/Forums/ope...tml#post552881
unfortunately, I couldn't motivate any expert on this topic to answer my question...
let us know, in case you found the solution to this task.
regards,
silvan
silvan is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
[General] Average of SLICE in Paraview Maurice Waldner ParaView 6 December 16, 2018 17:41
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
area weighted average or mass weighted average sa har Main CFD Forum 0 January 5, 2016 13:16
