October 9, 2016, 08:43 |
postChannel adapted to annular pipe flow
Francesco Garita
Rep Power: 9 |
Hi everybody,
I am setting up a LES for turbulent flow in annular pipe. After making the statistics, I have to extract a velocity profile of the time-averaged axial velocity component which should result from an average along the axial direction and along the azimuthal direction. In other words, I would need an application similar to what postChannel does, i.e. that computes the spatial average of a certain field, but that does it along axial and azimuthal directions (instead of axial and spanwise directions). Is there any application already written or do I have to modify postChannel by myself? Thank you, Francesco |
May 20, 2018, 11:07 |
Rep Power: 12 |
I am also very interested in such a utility or postChannel modification.
Has anyone already a solution for this? And one additional question: I have a orthogonal o-type grid near the cylinder wall and I can modify cells in axial, radial and azimuthal direction in blockmesh just by using the x y z directions. So, I know that OpenFOAM works in Cartesian coordinates ... when I postProcess and do time averaging (LES) I get the Uprime2Mean values ... are they now for x,y,z-directions or in axial, radial, azimuthal directions like the way the grid was defined??? thanks ... |
December 4, 2019, 07:44 |
Jianrui Zeng
Rep Power: 7 |
February 18, 2023, 09:23 |
Rep Power: 5 |
Anyone made it out after 4 years?
High values of heat transfer coefficient for laminar flow in pipe | Allankey | CFX | 2 | May 28, 2014 12:44 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 16:22 |
Vertical Pipe water flow | Goutam | FLUENT | 0 | April 30, 2014 08:25 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
