October 21, 2016, 03:31 |
fluentDataToFoam utility
harshawardhank
Rep Power: 13 |
Hello friends,
I want to use fluent data to openFoam simulation. for that purpose I am using fluentDataToFoam. I am able to compile this utility but some errors arise during using this utility. can any one tell me how to utilize the utility Create time Machine config: 600012484888 Grid size: nCells = 845880 nFaces = 2549411 nPoints = 854877 00Grid size: nCells = 1 nFaces = 4 nPoints = 1 _:�-� --> FOAM FATAL IO ERROR: wrong token type - expected int, found on line 0 the word ' ' file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, int&) in file primitives/ints/int/intIO.C at line 68. FOAM exiting |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
wallHeatFlux Calculation wrt utility version | ahmet | OpenFOAM Post-Processing | 1 | December 18, 2016 19:45 |
[mesh manipulation] mirrorMesh utility preserving regions | zfaraday | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2016 21:51 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
FluentDataToFoam utility | ali | OpenFOAM Post-Processing | 1 | November 24, 2005 13:44 |
