[PyFoam] problems with pyFoamSamplePlot.py
Old   October 22, 2009, 05:52
Assistant Moderator
Bernhard Gschaider
Originally Posted by olivier View Post
Then I am missing something, because I am poiting at the NumPy installation in the PYTHONPATH. I will try to have a look at it tomorrow. I hate when I am not admin...
Olivier
You're pointing AT numpy or one direcotry ABOVE it? Second is correct
Old   November 30, 2009, 04:09
Bernard Esterhuyse
bernarde is on a distinguished road
Hi all
I had the same problem with the blank gnuplot's:
Warning: empty x range [1:1], adjusting to [0.99:1.01]
Warning: empty y range [1:1], adjusting to [0.99:1.01]
I'm running Suse 11.1 and OF 1.6. I found the Numpy and Scipy aren't installed in Suse by default. Thus I had to install them from here:
http://software.opensuse.org/search
(just search for numpy and scipy and install both).
The plots then worked fine.
Regards
Bernard
bernarde is offline   Reply With Quote
Old   November 30, 2009, 04:14
Bernard Esterhuyse
Just another question - is there any way to zoom into certain areas of the plot?
If I right-click on the plot, I get a square that I can drag. I though this would produce a zoom of the area in the square, however I just get the following in the console:
line 0: warning: Skipping unreadable file "/tmp/tmpDLaJzj.gnuplot/fifo"
line 0: warning: Skipping unreadable file "/tmp/tmpRWr59v.gnuplot/fifo"
line 0: No data in plot
The plots just remain the same.
Old   November 30, 2009, 07:42
Assistant Moderator
Bernhard Gschaider
Originally Posted by bernarde View Post
Hi all
Regards
Bernard
Yeah. It seems there are problems with Numeric (which is used as a fallback if numpy is not installed) especially on SuSE. pyFoamVersion.py says something in that sense, but it is not very clear Bernhard
Old   November 30, 2009, 07:47
Assistant Moderator
Bernhard Gschaider
That is a problem of the gnuplot-terminal (which by default is x11). That can not do it. There are gnuplot-terminals that could do it, but they are not supported by pyFoam. What you can try with the most recent PyFoam is use the plotting-implementation matplotlib. That can do that (zooming). The problem is that it does not work on all platforms (only one of two I tested so far ), so: good luck Bernhard
Old   December 1, 2009, 10:12
Rasmus Hemph
hemph is on a distinguished road
Hi all
Regards
Bernard
Perfect! Got my graphs back again
//Rasmus
hemph is offline   Reply With Quote
Old   December 1, 2009, 11:07
Assistant Moderator
Bernhard Gschaider
Sorry for the misinformation: the x11 terminal CAN do zooming, BUT not if it gets the data from a pipe (which is the case here), so sorry no possibility. So the only way to zoom the graphs is to force writing of the data with --write-files and afterwards visualize that data with the plotting program of your choice (or use --start and/or --end if you'Re only interested in a certain time-range)
Bernhard
Old   January 3, 2011, 03:32
Default sorting of parsed dictionary
  #48
Fabian Braennstroem
braennstroem is on a distinguished road
Hello Bernhard,
I have trouble understanding the sorting of your parser using the below expression:
f=ParsedParameterFile(fileDict)
Keys=f["addLayersControls"]["nameConventions"].keys()
for the fileDict:
addLayersControls
nameConventions // alphabetic order
GRO { nSurfaceLayers 4; }
ROT { nSurfaceLayers 6; }
WW { nSurfaceLayers 12; }
I would like to have the same order as it is listed in the dict;
unfortunately I get this order: ['WW', 'GRO', 'ROT'].
Do you have a hint or idea, how to get this!?
Would be great!
Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   January 3, 2011, 05:47
Assistant Moderator
Bernhard Gschaider
Originally Posted by braennstroem View Post
Hello Bernhard,
for the fileDict:
addLayersControls
Would be great!
Regards!
Fabian
The problem is that a dictionary usually does not have an order of the keys (the order is determined by the implementation). In your example the order of the definition is also the alphabetical order. To get the keys in alphabetical order (which is probably not what you want in the general case) just add Keys.sort(). If you need the stuff in the order of the definition (which in my opinion is not a good idea because that would mean that your OF-code depends on that order too and things might break should the implementation of dictionary.toc change) then something about the library would have to be changed. A quick fix would be to go to Basics/DataStructures.py and add to DictProxy a method
def keys(self): return self._order
(self._order is used to output stuff int the order of the definition) but this fix will NOT change the order if you iterate over the dictionary itself (without .keys())
Bernhard
Old   January 3, 2011, 06:34
Fabian Braennstroem
Hi Bernhard,
thanks for the quick response!
Yes, I tried the sort(), but is not suitable for this task.
In this case, pyFoam is used as a preprossing tool setting the number of layers in snappyHexMeshDict based on given name conventions. So it 'just' creates the snappyDict according to another Dict... So similar to the regexp stuff from 1.6.x on, I would be able to first set all patches depended on the first entry and the second could overwrite the setting...
Works! Thanks!
Fabian
Old   January 4, 2011, 12:31
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Works! Thanks!
Fabian
In the fix I sent you replace self._order with self._order[:] (this creates a copy of the list which avoids possible side-effects should somebody modify the list he gets - the original for returned a reference to the list)
Bernhard
Old   September 30, 2011, 08:01
Tibor Nyers
Toorop is on a distinguished road
I would like to create a simple script that renders out a paraview state file at some time. I tried to reverse engineer your paraview related pyFoam utiliities and couldn't quite understand how the desired time is set.
My terminal command is:
paraview --script=./postproc/paraview/paraPlot.py
paraPlot.py
from paraview.simple import *
# load the state
servermanager.LoadState("./postproc/paraview/pw_pressure.pvsm")
# make sure that the view in the state is the active one
SetActiveView(GetRenderView())
GetActiveView()
# no success, no output
SetViewTime(800)
# now render and save
Render()
WriteImage("./postproc/paraview/pw_pic.png")
This method is not working, no output is generated. If I left out SetViewTime, there is a picture, but I guess paraview uses the time defined in the state file and my color isn't rescaled to data range as well.
My other try:
# load the state
# make sure that the view in the state is the active one so we don't have to refer to it by name
view=GetActiveView()
view.ViewTime=0
view.Render()
view.WriteImage("./postproc/paraview/pw_pic.png")
The color is rescaled, but no output.
In both cases the legends aren't scaled to data range.
Is there a solution or one should modify the state file instead?
What's the command for quiting paraview at the end of the script?
Can someone advise some tutorials on python scripting paraview - stream tracer creation, slicing and contour plots, etc? This state file loading is not really impressive, contains a lot of boiler plate stuff, hard to edit and customize. It would be much better the other way around.
Thank you!
Toorop is offline   Reply With Quote
Old   September 30, 2011, 08:28
Elvis
elvis will become famous soon enough
I think you are better served with Python Scripting http://paraview.org/Wiki/ParaView/Python_Scripting or http://paraview.org/Wiki/Take_a_Scre..._of_a_VTP_File
http://www.openfoamworkshop.org/6th_...rle_slides.pdf =>see slide Batch/reproducible workflow "topic macro"
elvis is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
