Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
FoamDataToFluent Problem
Old   May 30, 2008, 09:01
Default Hi, I have troubles in conve
Anand
aganesan is on a distinguished road
I have troubles in converting FOAMdata to Fluent
form. Basically these are the steps that I
followed for the cavity tutorial:
# I replaced the starttime with the latestTime option in the controlDict file.
# foamMeshToFluent $FOAM_RUN/tutorials/icoFoam cavity
Result: The foam mesh was converted to Fluent Mesh successfully in fluentInterface directory (cavity.msh)
# foamDataToFluent $FOAM_RUN/tutorials/icoFoam cavity
Result: --> FOAM FATAL IO ERROR : cannot open file
file: /home/ang/OpenFOAM/ang-1.4.1/run/tutorials/icoFoam/cavity/system/foamDataToFluen tDict at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
I have tried the same steps on some of my other
directories within OpenFOAM but I end up getting
the same result.
Any help on overcoming this problem would be greatly appreciated.
Thanks.
Anand
aganesan is offline   Reply With Quote
Old   May 30, 2008, 09:21
Default As FOAM tells you... It can no
BastiL
bastil is on a distinguished road
As FOAM tells you... It can not open file, I guess it is missing?
bastil is offline   Reply With Quote
Old   June 2, 2008, 17:45
Default I have the same problem too. W
Ruth Oh
ruthie is on a distinguished road
I have the same problem too. What can be done to resolve the problem? Do you need to type something in the command line to generate the foamDataToFluentDict file? Or does it come pre-installed?
ruthie is offline   Reply With Quote
Old   June 3, 2008, 15:25
Default Yes, that certainly helps. Tha
Ruth Oh
Yes, that certainly helps. Thanks!
Old   June 3, 2008, 17:13
Default I should add that now when I t
Ruth Oh
I should add that now when I type "fluent 3d" in the command line, it isn't recognized in my computer. Any suggestions on what to do?
Old   June 3, 2008, 17:39
Default Ruth, I'm not sure I get your
Philippe B. Vincent
philippebv is on a distinguished road
Ruth, I'm not sure I get your problem. Would this command launch Fluent before and now it doesn't?
philippebv is offline   Reply With Quote
Old   June 3, 2008, 18:21
Default Sorry, I should clarify. What
Ruth Oh
Sorry, I should clarify. What I mean is that both before and after adding the foamDataToFluentDict file, I had the error that my computer won't recognize "fluent 3d".
Perhaps I should ask this question: Do you need to do anything during the installation to run Fluent? Do I need to install an extra component?
Old   June 4, 2008, 08:45
Default Ruth, Fluent is a commercial c
Philippe B. Vincent
Ruth, Fluent is a commercial code that is not related to OpenFOAM. The foamDataToFluent converter allows to do post-processing with Fluent only if it is installed on your computer. If you don't have Fluent installed, I suggest you use paraFoam for post-processing. Also, there are other converters that you can find in the forum like foamToTecplot or foamToCGNS.
Regards
Old   June 4, 2008, 17:15
Default Thanks Philippe. I am a new us
Ruth Oh
Thanks Philippe. I am a new user of OpenFOAM and I just wanted to try the various methods you could use to postprocess the data from OpenFOAM.
FoamDataToFluent maritozzo OpenFOAM Post-Processing 34 December 14, 2020 12:33
FoamDataToFluent dnomdec OpenFOAM Post-Processing 8 July 31, 2013 11:07
Error whit foamDataToFluent matteo_gautero OpenFOAM 1 November 12, 2012 04:46
FoamDatatoFluent BC achuneka OpenFOAM Post-Processing 4 August 16, 2008 11:21
Thread id problem foamDataToFluent achuneka OpenFOAM Post-Processing 0 June 6, 2008 10:25
