Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamDataToFluent
Old   October 6, 2011, 14:38
Default foamDataToFluent
andres
greel is on a distinguished road
Hi I´m trying to export the openfoam data to fluent, but when I use the foamDataToFluent command I get an error.
I´m running the elbow test case from incompressible/icoFoam tutorials folder.
After I run the icoFoam solver I do this:
foamDataToFluent elbow.msh
Getting this error [QUOTE]
usuarioubuntu@SAN1496UBU:~/OpenFOAM/usuarioubuntu/run/tutorials/incompressible/icoFoam/elbow$ foamDataToFluent elbow.msh
Usage: foamDataToFluent [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-latestTime select the latest time
-noFunctionObjects
do not execute functionObjects
-noZero exclude the '0/' dir from the times list, has precedence
over the -zeroTime option
-time <ranges> comma-separated time ranges - eg, ':10,20,40-70,1000:'
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-2.0.0 (see www.OpenFOAM.com)
Build: 2.0.0-d79727c3fca7
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 1
FOAM exiting
[/QUOTE
Thanks!
greel is offline   Reply With Quote
FoamDataToFluent maritozzo OpenFOAM Post-Processing 34 December 14, 2020 12:33
FoamDataToFluent dnomdec OpenFOAM Post-Processing 8 July 31, 2013 11:07
foamToVTK & foamDataToFluent problem! germinal OpenFOAM Bugs 1 August 17, 2010 05:02
FoamDatatoFluent BC achuneka OpenFOAM Post-Processing 4 August 16, 2008 11:21
FoamDataToFluent Problem aganesan OpenFOAM Post-Processing 8 June 4, 2008 17:15
