Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
U_tauchannel flow
Old   July 6, 2007, 07:45
Default Hi to all, I am simulating
hadi tartoussi
hadi is on a distinguished road
Hi to all,
I am simulating a LES turbulent channelflow using channelOodles, i fixed the value of Ubar and i ran the case for few iterations, i would like to get the values of u_tau in order to estimate the corresponding Re_tau.
Does openFoam print out these values?
u_tau=(nu*(du_x/dy+du_z/dy))^0.5
Thanks in advance
hadi
hadi is offline   Reply With Quote
Old   July 6, 2007, 07:49
Default please Hady try not to make a
Maka Mohu
maka is on a distinguished road
please Hady try not to make a new thread for every new question you have. In this way, you make your chances to get answer lower and also make it harder for others to follow the topics. There are several posts on channelOodles. Post on one of them your question.
Have a nice day,
Maka
maka is offline   Reply With Quote
Old   July 6, 2007, 08:27
Default Sorry Maka, you are right,but
hadi tartoussi
Sorry Maka, you are right,but i thought that old threads are closed.
Cheers
Hadi
Old   July 6, 2007, 08:51
Default On the contrary some users get
Maka Mohu
On the contrary some users gets an email alert (check Edit Profile) when one of the the threads that they used has a new question. As a result, your chance is higher to get an answer for a question if you managed to find a thread that "related to it". The last part is important otherwise, your message may be ignored. It is OK, I have done the same when I started. I just learned that by trial and error :-). Good luck with your computations. Have a nice day!
Best regards,
Maka
Old   July 9, 2007, 03:35
Default Thanks Maka for your advice, i
hadi tartoussi
Thanks Maka for your advice, i will repost my message in an old thread
Cheers
Hadi
results for flow past flat plate normal to flow lisa Main CFD Forum 2 August 30, 2005 16:36
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 13:41
