Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Modify the reconstructPar to delete the reconstructed parallel directories within the loop
Old   December 13, 2005, 05:22
Default I'm solving a case with big nu
Maka Mohu
maka is on a distinguished road
I'm solving a case with big number of nodes and I need to save the instantaneous data. I need to modify the reconstructPar to delete the reconstructed parallel directories (within the reconstruction loop). I need to add an option to the command -savestorage which let the reconstructPar delete the reconstructed directory after reconstructing it. This can not be done at the end since the data are near a terra bite. I would be gratefule if any body can help.
Best regards,
Maka
maka is offline   Reply With Quote
Old   December 14, 2005, 07:21
Default I checked util/parallel/recost
Maka Mohu
I checked util/parallel/recostructPar.C. I know where (end of time-directories loop) to put the delete statement but I can't figure out what should I write to delete the folder. Can any body help.
Regards,
Maka
Old   December 16, 2005, 10:37
Default Try for(label np = 0; np <
Eugene de Villiers
eugene is on a distinguished road
Try
for(label np = 0; np < nProcs; np++)
rmDir(mesh.path()/fileName(word("processor")+Foam::name(np)));
or something similar.
Foam wrappers for a lot of system commands can be found in Unix.C.
eugene is offline   Reply With Quote
Time directories robbo OpenFOAM 1 May 21, 2008 16:49
Face loop in a Parallel UDF Dario FLUENT 4 May 10, 2007 08:34
Script for generating lnInclude directories brooksmoses OpenFOAM 4 January 26, 2006 19:02
Modifing reconstructPar to delete the reconstructed parallel directories maka OpenFOAM Pre-Processing 1 December 13, 2005 07:16
loop(p,I->p) how this loop works? Sinan FLUENT 0 January 18, 2005 18:04
