Sample utility not working in OpenFoam1.5 dev |
December 9, 2009, 11:46 |
Hi foamers,
I am trying to use the sample utility in OpenFoam 1.5 dev version. I tried to use the example available in the tutorial of solidDispacementFoam, as refered in the user's manual, but, it seems it did not worked. Although the sample utility worked and (no error message), no sets directory can be found directory. Of course I ran the case previously, so the sample utility can have data to work on. After the calculations ended, I wrote in the command line sample. No sets directory, or samples directory, created. The same thing happens in OpenFoam 1.5, official release. I am using a OpenFoam in Ubuntu 8.1. Am I doing something wrong? Regards, António Martins |
December 10, 2009, 02:38 |
Mark Olesen
Rep Power: 40 |
Sample utility problems | msrinath80 | OpenFOAM Running, Solving & CFD | 12 | December 21, 2012 05:51 |
PostChannel utility not working in OpenFoam 15 | nishant_hull | OpenFOAM Running, Solving & CFD | 15 | January 18, 2012 05:26 |
ICC compiler and sigFpe for sample utility | cfdmarkus | OpenFOAM Installation | 3 | June 25, 2010 14:31 |
Sample utility problem in OpenFOAM141dev | 7islands | OpenFOAM Bugs | 1 | January 4, 2008 08:34 |
Problem with sample utility | roberthino | OpenFOAM Post-Processing | 6 | August 23, 2007 15:29 |
