Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
sample utility problem
Old   April 16, 2012, 14:40
Caroline Vandame
CaroVandame is on a distinguished road
But doesn't the error message means that the keyword patches should be defined in the surfaces section?
"keyword patches is undefined in dictionary "/home/caro/OpenFOAM/caro-2.1.0/run/pipe_flow/system/sampleDict::surfaces" "
CaroVandame is offline   Reply With Quote
Old   April 16, 2012, 14:45
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
It couldn't find the keyword "patches" and checking the dict given with the source code, this keyword is present only in the sets section. The idea is to try adding something in this section to see what happens.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 16, 2012, 14:56
Caroline Vandame
so using the tutorial LadenburgJet60psi as a guide (because they also want to sample for a wall property), here is what I wrote
sets
face
name cyl_Wall;
axis x;
start (0 0.05 0);
end (10 0.05 0);
nPoints 100;
But now I get this error:
keyword type is undefined in dictionary "/home/caro/OpenFOAM/caro-2.1.0/run/pipe_flow/system/sampleDict::sets"
I must be missing something obvious, I just don't see it...
Old   April 16, 2012, 14:59
Yes,
type uniform;
at the beginning of the definition.
Research Scientist
Old   April 16, 2012, 15:02
Caroline Vandame
And now I get my "keyword patches undefined ..." error again...
Old   April 16, 2012, 15:05
What FOAM version are you using?
Research Scientist
Old   April 16, 2012, 15:06
Caroline Vandame
OpenFOAM 2.1.0
Old   April 16, 2012, 16:13
Please check:
/opt/openfoam<your_version>/applications/utilities/postProcessing/sampling/sample/sampleDict
in order to see the correct wording of the dictionary, the keywords have changed in the last versions. Now the keyword patches is required in surfaces too.
Regards.
Research Scientist
Old   April 16, 2012, 17:24
Caroline Vandame
Thanks so much for your help Santiago!!!
It seems you do not need to specify anything in sets, as long as everything is defined correctly in surfaces.
Old   April 16, 2012, 17:27
You welcome. Yes, sets is not more needed. It was used only for testing purposes.
Bye.
Research Scientist
Old   June 6, 2012, 20:42
Default sampleDict surfaces with moving mesh
  #31
cutty4sark is on a distinguished road
I was wondering if anyone has used the sampleDict to determine variable values along a moving mesh. Particularly, I'm interested in the displacement of a solid in an FSI case (Turek and Hron benchmark). It would be very similar to determining the displacement of the tip of the console in the flappingConsole FSI case that is packaged with the extend versions of 1.5 and 1.6. I've tried using the surfaces functionality of the sampleDict and like many other folks end up with empty file folders. This leads me to believe there are issues with trying to use the boundaries/interfaces between solid and fluid as my surface patch like others have experienced. This also brings me to the issue of trying to define a line or surface based on xyz coordinates as I'm interested in the variation of x,y,z over time as the solid is deflected. Any help would be appreciated and I'm curious if anybody else has experienced this as I couldn't find anything in the forums.
Regards,
Andrew
cutty4sark is offline   Reply With Quote
Old   September 13, 2012, 03:00
Default About installation of swak4Foam
  #32
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi everyone,
I am fresher to openFoam. I came to know the uses of swak4Foam utility for writing boundary conditions. In my application also i need to apply zero flux boundary condition. So i wish to install swak4Foam. Now i am working on OF 2.1.1 version.
I followed every step as mentioned in the tutorials but i am not able to get it. The error message as follows
Error message:-
malli_reddy@ubuntu:~/OpenFOAM/malli_reddy-2.1.1$ svn checkout https://openfoam-extend.svn.sourcefo...ies/swak4Foam/
svn: OPTIONS of 'https://openfoam-extend.svn.sourcefo...ries/swak4Foam': Could not resolve hostname `openfoam-extend.svn.sourceforge.net': No address associated with hostname (https://openfoam-extend.svn.sourceforge.net)
Could you please suggest me how to overcome this problem. And suggest me some good tutorial for the swak4Foam.
Thanks
Regards
mmkr825 is offline   Reply With Quote
Old   June 19, 2013, 22:24
legenoy is on a distinguished road
Regards,
Andrew
I am using FSI for my work. I find Sample with OF-1.6 have some problems and I always have failed to get displacement with sample. Could you please suggest me how to overcome this problem?
Thanks
Regards
Legenoy
legenoy is offline   Reply With Quote
Old   May 19, 2014, 09:21
Default set file missing when using sample
  #34
Josefina is on a distinguished road
Hello Everybody!
I am quite new with Open Foam and I try to use the sample utility. I read the very interesting questions and answers and I saw that sometimes the files in the set file are empty.
My problem is that the set file is not even created in my case directory. When I apply the sample utility I get this:
Create time
Create mesh for time = 0
Time = 0
Time = 0.1
Time = 0.2
Time = 0.3
Time = 0.4
Time = 0.5
Time = 0.6
Time = 0.7
Time = 0.8
Time = 0.9
Time = 1
End
So I think the utility works but I did not find how to create the set file. Somebody can help me please?
Josefina is offline   Reply With Quote
Old   May 20, 2014, 05:08
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
If the sample utility does not find the specified field in the time step then it skips the time step.
Can you post you sampleDict here?
Philip
bigphil is offline   Reply With Quote
Old   May 20, 2014, 05:15
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Did you look in postProcessing/sets folder?
alexeym is offline   Reply With Quote
Old   May 20, 2014, 08:50
Hi!
Before all, thank you for your answers!
Here you can find my sampleDict file:
setFormat raw;
surfaceFormat raw;
formatOptions
ensight
format ascii;
interpolationScheme cell;
fields
p_rgh
U
alpha1
sets
lineX1
type uniform;
axis xyz;
start (0. 0.0 0.1);
end (0.2 0. 0.18);
nPoints 10;
lineX2
type face;
axis xyz;
start (0. 0.1 0.1);
end (0. 0.2 0.1);
somePoints
type cloud;
axis xyz;
points ((0.0 0.0 0.15)(0.2 0.2 0.15));
I think I had a problem of OpenFoam version. I have written "sampleSets" instead of "sets" but now it works! and the "sets" file is indeed created in the "postProcessing" file.
Sample utility Gearb0x OpenFOAM Post-Processing 13 April 30, 2019 12:16
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Sample utility not working properly titio OpenFOAM 2 June 9, 2010 10:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
