Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
[Paraview] Selection of Integration's Result
Old   May 12, 2011, 08:08
Default [Paraview] Selection of Integration's Result
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I need to get the result of the integration of an calculator for further computation.
From this calculator, I select Filter " Integrate Variables"
Instead of getting the integration of my calculator I get also integration's result from p, k , epsilon.
How to select only what I am interested?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 13:42
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 10:27
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 05:25
In a distance above the ground, my LES result is not good panda60 OpenFOAM 2 January 22, 2010 07:52
LES result harrislcy FLUENT 1 December 28, 2009 06:29
