[swak4Foam] Variable T_inf for convection problem in a pipe using groovyBC
Old   September 4, 2013, 13:50
Default Variable T_inf for convection problem in a pipe using groovyBC
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hi all,
I am trying to simulate a simple pipe with constant heat flux walls, which are cooled by fluid flow going through the pipe.
Here is an image for better illustration:
Here is what I am gonna do. For wall BC I want to use:
dT/dn= (q-h*(T-T_inf))/(k_f)
In which T_inf is the average bulk temperature of the fluid, which varies across the pipe.
To calculate bulk temperature I want to use the average value of T as a variable of x (Length from the inlet).
How can I calculate this average in each x and use it as T_inf?
Is it possible to do this using groovyBC?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   September 4, 2013, 15:08
Assistant Moderator
Bernhard Gschaider
Originally Posted by Mojtaba.a View Post
Hi all,
Not the way you'd want to.
The first thing is that T_avg(s) is not really well defined after the pipe bend (BTW: convention is that x is a component of cartesian coordinates. The string length which you mean is s. At least the way I learned it). So the first thing would be to specify/calculate it for the whole geometry. Then you can calculate your T_avg(s) (for this there is actually a functionObject swakExpressionAverageDistribution in the development verson. But currently there is no way to feed that data back to your BC)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 4, 2013, 15:50
Mojtaba.a's Avatar
Thank you Bernhard.
Old   September 4, 2013, 18:21
Joachim Herb
jherb is on a distinguished road
Why don't you use the turbulentHeatFluxTemperature boundary condition?
See also http://www.cfd-online.com/Forums/ope...mperature.html
jherb is offline   Reply With Quote
Old   September 4, 2013, 19:10
Assistant Moderator
Bernhard Gschaider
In principle you're right. The problem is the T_inf he wants: an average of the T in the fluid. I don't think turbulentHeatFluxTemperature does that (last time I looked you specified the T_inf. It didn't get calculated from the solution)
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 00:19
[swak4Foam] GroovyBC problem in the defining inlet velocity iampolaris OpenFOAM Community Contributions 7 October 18, 2014 09:25
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
