July 10, 2014, 07:26 |
wallHeatFlux
Michael
Rep Power: 13 |
Hello everyone,
I am currently using and modifying the wallHeatFlux utility in order to calculate other values, that are calculated from the heat flux. However, I am not quite sure how the utility calculates the heat flux... to be specific, I don't quite get this part: Code:
surfaceScalarField heatFlux ( fvc::interpolate ( ( turbulence.valid() ? turbulence->alphaEff()() : thermo->alpha() ) )*fvc::snGrad(h) ); I am using OpenFOAM 2.2.x I would really appreciate it, if someone could assist me with this by pointing out which equation is being used here to calculate q. Thanks in advance. |
July 14, 2014, 05:18 |
Michael
Rep Power: 13 |
Does anyone know how it works??
alpha, heat transfer, wallheatflux |
wallHeatFlux and radiation | craig.tickle | OpenFOAM Post-Processing | 5 | December 2, 2018 08:00 |
Local heat transfer / modifying wallHeatFlux | buck_s | OpenFOAM Post-Processing | 0 | June 17, 2014 06:52 |
problem with WallHeatFlux | Roman1 | OpenFOAM Running, Solving & CFD | 1 | January 24, 2014 10:31 |
wallHeatFlux BC not constant after restart | eelcovv | OpenFOAM Running, Solving & CFD | 26 | May 24, 2011 23:11 |
[swak4Foam] groovyBC + wallHeatFlux BC | prabhu | OpenFOAM Community Contributions | 1 | July 21, 2009 10:56 |
