Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Sample utility only samples pressure?! (not velocity)
Old   May 14, 2012, 09:03
Default Sample utility only samples pressure?! (not velocity)
cfddwarf is on a distinguished road
Hello!
Iam currently trying to postsrocess my results and for this I would like to use the sample utility.
However it doesnt sample the velocity!? Ive tried mag(U) in fields or only u and it doesnt work. The files for the pressure are created. Does anyone have any idea what the reason could be? Do I HAVE to run foamCalc before? Ive tried running
foamCalc mag U before, this worked. Any help would be appreciated!
My sampledict file looks as follows:
interpolationScheme cellPoint;
setFormat raw;
sets
line1
type uniform;
axis y;
start ( 0.0002 0.00001 0 );
end ( 0.0002 0.0029 0 );
nPoints 50;
line2
type uniform;
axis y;
start ( -0.0004 0.00001 0 );
end ( -0.0004 0.0029 0 );
nPoints 50;
line3
type uniform;
axis y;
start ( 0.0002 0.00001 0.0002 );
end ( 0.0002 0.0029 0.0002);
nPoints 50;
line4
type uniform;
axis y;
start ( 0 0.00001 0.0005 );
end ( 0 0.0029 0.0005 );
nPoints 50;
surfaces ();
fields (u
p);
cfddwarf is offline   Reply With Quote
Old   May 14, 2012, 12:31
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Most of FOAM is case sensitive. What happens when you sample "U" instead of "u"? Or is the field as it is written in the solver you are using called "u", or is this an artifact of copying your sampleDict into the forum?
mturcios777 is offline   Reply With Quote
Old   May 14, 2012, 12:36
ok, problem solved. foamCalc mag U has to be done first and in the sample dict file it has to be specified as "magU"
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Sample utility not working in OpenFoam1.5 dev titio OpenFOAM Post-Processing 1 December 10, 2009 02:38
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
how to print the results from CFX-4.2 cfd_99 Main CFD Forum 5 June 21, 1999 09:23
