ansys to foam and solve with dsmc
Old   October 21, 2012, 16:07
Unhappy ansys to foam and solve with dsmc
hadi abdollahzadeh
dark lancer is on a distinguished road
hi
I am beginner in the openfoam and decide to solve a problem with dsmc code.
I create my body in catia and then import it to ansys and I use workbench to create my mesh file(.msh) and then I create a newfolder and create (0,constant and polyMesh,system) but those are empty and then I put my (.msh)file into my polyMesh then run fluentmeshtofoam and I see this:
[hadi@hadi polyMesh]$ fluentMeshToFoam hemishpherical.msh
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : fluentMeshToFoam hemishpherical.msh
Date : Oct 21 2012
Time : 21:46:05
Host : "hadi.msi"
PID : 3346
Case : /home/hadi/OpenFOAM/OpenFOAM-2.1.1/tutorials/discreteMethods/dsmcFoam/bluntbodyathypersonic/constant/polyMesh
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/hadi/OpenFOAM/OpenFOAM-2.1.1/tutorials/discreteMethods/dsmcFoam/bluntbodyathypersonic/constant/polyMesh/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
now I don't know what I have to do for create the for example fvsolution or iDof ,rho,momentum and other the files?
dark lancer is offline   Reply With Quote
Solve Simple foam for laminar flow nandiganavishal OpenFOAM Running, Solving & CFD 4 January 20, 2009 00:56
msha solve Eqn programming in C using FOAM msha OpenFOAM Running, Solving & CFD 2 January 6, 2008 07:03
msha solve Eqn programming in C using FOAM msha OpenFOAM 2 December 30, 2007 02:39
Can the FOAM solve the conjugate heat transfer problem ztdep OpenFOAM Running, Solving & CFD 1 September 15, 2005 14:26
FOAM licensed free to academic institutions Nabla Ltd. Main CFD Forum 0 November 18, 2002 10:24
