outlet boundary condition for open environment
Old   March 1, 2014, 22:08
Prasad
mprasad is on a distinguished road
Dear all,
I am trying to simulate current flow in a tank with open environment at the outlet. I have tried several ways only to find that the current is reflected at the outlet causing water level to rise in the tank.
I am running a simple case where current is generated at the inlet using waves2foam.
I would like to simulate an open environment for my outlet boundary condition.
But I find that the current flow does not leave the tank but is reflected.
Is there something wrong with my outlet boundary conditions ?
These are my boundary conditions for the outlet
alpha1:
type zeroGradient
p_rgh :
type buoyantPressure
value uniform 0
U:
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
*internal Field was set to uniform (0 0 0)
I would also like to ask does setting potential current (0 0 0) in the wave properties file for the outlet absorb current generated at the inlet?
Thank you.
Regards,
Prasad
mprasad is offline   Reply With Quote
Old   March 2, 2014, 03:49
Prasad
Hi all,
With regards to my earlier query, attached are the sectional views for alpha1 and U.
The current flow for the inlet which is at the left is 2 ms-1.
Thank you.
Regards,
Prasad
Outlet boundary condition for a heated tube flow JinBiao OpenFOAM Running, Solving & CFD 0 July 28, 2012 03:56
pressure outlet boundary condition liladhar STAR-CCM+ 6 May 12, 2012 05:09
Boundary Condition outlet natantyt FLUENT 0 September 27, 2010 15:30
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Outlet boundary condition Asghari Main CFD Forum 0 May 5, 2006 16:51
