Error during Parallel Running
Old   February 7, 2013, 03:05
Default Error during Parallel Running
sfigato's Avatar
Marco Longhitano
sfigato is on a distinguished road
Send a message via Skype™ to sfigato
Hi Foamers,
I would like to run in parallel my test case. I am using simpleFoam solver. So, This is my dict file:
| \\ / O peration | Version: 1.7.1 |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object decomposeParDict;
numberOfSubdomains 4;
method scotch;
simpleCoeffs
n ( 2 2 1 );
delta 0.001;
hierarchicalCoeffs
n ( 1 1 1 );
delta 0.001;
order xyz;
metisCoeffs
processorWeights ( 1 1 1 1 );
manualCoeffs
dataFile "";
distributed no;
roots ( );
After run the decomposePar utility..I got thi error:
--> FOAM FATAL ERROR:
You are trying to use scotch but do not have the scotchDecomp library loaded.
This message is from the dummy scotchDecomp stub library instead.
Please install scotch and make sure that libscotch.so is in your LD_LIBRARY_PATH.
The scotchDecomp library can then be built in $FOAM_SRC/parallel/decompose/decompositionMethods/scotchDecomp
From function labelList scotchDecomp::decompose(const pointField&, const scalarField&)
in file dummyScotchDecomp.C at line 113.
Then, I switched scotch with simple and the decomposition works fine. Nevertheless, when I run my mpirun I got this error:
Trying to use the dummy Pstream library.
This dummy library cannot be used in parallel mode
From function UPstream::init(int& argc, char**& argv)
in file UPstream.C at line 37.
FOAM exiting
Can anyone help me, please?
I deepen the problems. During the building of scotch and dummy, I do not have mpi.h and scotch.h!
My OpenFOAM version is 2.1.x anyone knows if there is an unsolved bug about parallel computation?
Regards
Marco
sfigato is offline   Reply With Quote
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
Running mapFields with Parallel Source and Parallel Target RDanks OpenFOAM Pre-Processing 4 August 2, 2016 05:24
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 08:53
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 03:50
Running in parallel crashed zhajingjing OpenFOAM 4 September 15, 2010 07:12
