time-varying internalField
Old   February 8, 2013, 02:45
Default time-varying internalField
Klio
klio is on a distinguished road
Hello!
I edited the chtMultiRegionFoam Solver so that it is possible to add a volumetric heat source to a region!
Now I want to implement a circuit where the heat source is switched on and off.
The problem is that the heat source entry has to be changed in the internalField because it is volumetric -> If i change the BC with timeVaryingMappedFixedValue of course it has no effects on the simulation !
Does anyone know how to fix that Problem?
Thanks! Klio
klio is offline   Reply With Quote
Old   February 10, 2013, 06:24
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by klio View Post
Hello!
Thanks! Klio
You'll have to customize the solver to include a volumetric source. Either application-specific or by adding expressionSource from swak (see discussions on that elsewhere on the forum) or adding the basicSource that is available in OF 2.1 (not aware of a recipe how to do that but its not that difficult). The last option allows a runtime-selectable subclass (and there is also a swak-implementation for that) so it is the most flexible
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   February 19, 2013, 03:28
Klio
Ok thank you!
I'll take a look on it!
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
time varying boundary condition cfd-student CFX 0 April 15, 2008 08:31
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
