Problem with constant Heat Flux
Old   April 14, 2015, 15:27
Unhappy Problem with constant Heat Flux
Hesam
rapierrz is on a distinguished road
Hi friends,
I add temprature to icofoam with openfoam wiki tutorial :
https://openfoamwiki.net/index.php/H...ure_to_icoFoam
and in Temprature boundary condition I define constant heat flux condition for lower wall:
lowerWall
type groovyBC;
valueExpression "300";
gradientExpression "q";
fractionExpression "0";
variables "q=300;";
timelines ();
value uniform 300;
but when openfoam solve the problem,Temprature after 100 second become 4000-22000K!!!
I'm very cunfused.please Help me
rapierrz is offline   Reply With Quote
Old   April 17, 2015, 11:20
Agustín Villa
agustinvo is on a distinguished road
Hello
with GroovyBC, you are imposing a gradient of temperature, not a heat flux... to do that, you should express this gradient in function of your heat flux, and the kinematic and turbulent thermal diffusivities.
Other option you have is the use of turbulentHeatFluxTemperature BC.
agustinvo is offline   Reply With Quote
Old   April 19, 2015, 00:05
Hesam
Thank you Agustin,
I think When we have a fixed heat flux condition,gradient of temprature on
the wall is constant.
k*gradT=q , gradT=q/k;
Do you think I impliment bad boundary condition with groovyBC?
Old   April 20, 2015, 07:30
Agustín Villa
if you are using RANS models, the expression you propose should be modified to:
q=k_eff*gradT
where k_eff=k+k_turb, k is the thermal conductivity, and k_turb is the turbulent thermal conductivity. This expression is taken into account in the BC I told you. In case you want to use GroovyBC, you should divide by the effective thermal conductivity.
clarification about constant heat flux boundary condition at wall in fluid region baran_foam OpenFOAM Post-Processing 5 November 26, 2016 17:57
UDF for a constant heat flux minus radiation based on face temperature MarioArias Fluent UDF and Scheme Programming 3 March 10, 2015 15:54
Problem with snGrad() for heat flux. SKLee OpenFOAM Programming & Development 4 March 4, 2014 22:46
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Constant heat flux ocy FLUENT 1 January 17, 2005 01:54
