Geometry in OpenFoam
Old   May 22, 2013, 08:30
Default Geometry in OpenFoam
Amin
Mirage12 is on a distinguished road
Hello everyone,
I am a new OpenFoam-user and have a lot of questions.... i read the User-guide...but still not understanding , how really openfoam works....
so...first of all .... i am interested on the geometry in OpenFoam:
I would like to understand, how OpenFoam builds the geometry..where can i find the information concerning the geometry, that i want to simulate ?
how can know....if my geometry is an air foil, a cylinder or a cavity ?
how can i import CAD-files into OpenFoam ? how can use geometries, that i drew using a CAD-software ? should i only use the stl format ?
Thanks a lot !!!!!
Mirage12 is offline   Reply With Quote
Old   May 23, 2013, 13:59
Jace
zhengzh5 is on a distinguished road
Originally Posted by Mirage12 View Post
Hello everyone,
Thanks a lot !!!!!
hey,
OpenFOAM has 2 general approaches for building geometries: blockMesh and snappyHexMesh.
BlockMesh is typically used for simple geometries, you basicaly define points and builds blocks from them. You can read this for more detailed information. http://www.openfoam.org/docs/user/blockMesh.php
Other way to generate geometry in OpenFOAM is using snappyHexMesh, it takes a stl file as input, and there's various parameters to control the quality of the resultant mesh. for more detail, read this
http://www.openfoam.org/docs/user/snappyHexMesh.php
A tutorial on snappyHexMesh is located at /tutorials/mesh/snappyHexMesh/
That should get you going
zhengzh5 is offline   Reply With Quote
Old   May 24, 2013, 00:05
Amin
thank you
but how can i import CAD-files into OpenFoam ? how can i use geometries, that i drew using a CAD-software ? should i only use the stl format ?
Old   May 24, 2013, 00:11
Jace
thank you
Yah, export your geometry into stl files, and use snappyHexMesh to generate the mesh. That will require a background mesh generated using blockmesh and a file called snappyHexMeshDict in the system directory. A sample snappyHexMeshDict can be found in the tutorial link I posted earlier.
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
[Gmsh] gmsh 2.6.0 conversion to OpenFoam 160 rosswin OpenFOAM Meshing & Mesh Conversion 0 March 5, 2013 07:34
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
