SnappyHexMesh& extrudeMesh
Like Tree10Likes
Old   June 2, 2013, 17:02
immortality's Avatar
Ehsan
immortality is on a distinguished road
another error occurred in performing extrudeMesh,I changed that address also:
ehsan@Ehsan-com:~/Desktop/Files/airfoil_simpleFoam_modified$ extrudeMesh
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.0-b363e8d14789
Exec   : extrudeMesh
Date   : Jun 03 2013
Time   : 01:26:22
Host   : "Ehsan-com"
PID    : 3143
Case   : /home/ehsan/Desktop/Files/airfoil_simpleFoam_modified
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting extrudeModel linearNormal
Extruding from patch using model linearNormal
Collapsing edges < 0.0001 of bounding box
Extruding patches 1(front) on mesh "../aifoil_snappyHexMesh_modified2"
--> FOAM FATAL IO ERROR:
cannot find file
file: ../aifoil_snappyHexMesh_modified2/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
I'll continue tomorrow,bye for now
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 2, 2013, 17:08
s.m
saeideh mohamadi
s.m is on a distinguished road
Exec   : extrudeMesh
Date   : Jun 03 2013
Time   : 01:26:22
Host   : "Ehsan-com"
PID    : 3143
nProcs : 1
Create time
cannot find file
FOAM exiting
Dear ehsan, these two folders "airfoil_snappyHexMesh_modified2" and "simpleFoam_simpleFoam_modified" should be in on folder beside each other.
thanks
s.m is offline   Reply With Quote
Old   June 2, 2013, 17:26
Ehsan
yes they are in a unique folder beside to each other.
maybe this line have any problem?
sourceCase "../aifoil_snappyHexMesh_modified2";
is it right? it doen't find controlDict.
Old   June 3, 2013, 01:55
s.m
saeideh mohamadi
after finishig the analysis in airfoil_snappyHexMesh you now have "1,2,3,4" folders, yes?
now go to the airfoil_simpleFoam and write the name of the folder that you run the snappyHexMesh in it that is contain of "1,2,3,4" folders.
after this come to airfoil_simpleFoam that is contain "0,constant,system" and run extrudeMesh, and simpleFoam at the end.
Old   June 3, 2013, 01:58
s.m
saeideh mohamadi
Originally Posted by nimasam View Post
dear saide
check which side of 3D body, are you going to extrude?
are both sides (front and back) are the same?
Dear Nima i have extruded the front face, would you please take look at extrudeMeshDict in the attachment?
Old   June 3, 2013, 02:08
s.m
saeideh mohamadi
thanks
this error is because of you run the extrudeMesh in a wrong folder. you should go to the airfoil_simpleFoam then run the extrudeMesh there to give you polyMesh, in the constant folder of it.
Old   June 3, 2013, 03:29
Ehsan
Hi Saideh
I run the command in true folder but there are only "1,2,3" folders in airfoil_snappyHexMesh_modified2.
which version are you using?
there is an error on snapEdge:
ehsan@Ehsan-com:~/Desktop/Files/airfoil_snappyHexMesh_modified2$ snapEdge
snapEdge: command not found
what does do this command?
Old   June 3, 2013, 05:14
Nima Samkhaniani
nimasam is on a distinguished road
your extrudeMeshDict are completely right , did you check your mesh before extrusion? check whether it is front and back are the same
s.m likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 3, 2013, 07:57
s.m
saeideh mohamadi
Hi Saideh
openFoam does not have snapEdge dictionary you should compile it to your openFoam before running the snapEdge in the terminal.
it doesn't necessary for this multi element airfoil. run snappyHexMesh without the snapEdge. so it should create 3 folders for you.
Old   June 3, 2013, 08:00
s.m
saeideh mohamadi
yes i check the mesh, after finishing the SHM. the picture that i put in the 1th post is before layering , after layering and after extrudeMesh.
would you please take a look on my snappHexMesh file?
Old   June 3, 2013, 10:05
Ehsan
how to compile snapEdge?
now its running for 30 minutes.
the problem is on the values?
how is the order of coefficients?flap,main,slat from above to bottom?
what is Cl(f) and Cl(r)?
Cm    = 0.377331
    Cd    = 0.165487
    Cl    = 0.234554
    Cl(f) = 0.494607
    Cl(r) = -0.260054
Old   June 3, 2013, 13:36
Nima Samkhaniani
1- i know there is difference in mesh shape before and after extrusion you insist on it several times , my question was whether front and back face before extrusion after snappyHexMesh have the same shape
still waiting for your response
2- your snappyHexMesh is fine enough
Old   June 4, 2013, 01:27
s.m
saeideh mohamadi
of course they have the same shape, i attach some picture from front and back views of my snappyHexMesh
Old   June 4, 2013, 01:52
s.m
saeideh mohamadi
Cm    = 0.377331
    Cd    = 0.165487
    Cl    = 0.234554
    Cl(f) = 0.494607
    Cl(r) = -0.260054
i write three function for three element separately, so you should get three group result for "cd, cl and cm" as i know the cl for main element should reach 2.44, and 0.24 for flap.
Old   June 4, 2013, 05:14
Nima Samkhaniani
i have no more clue in my mind, be lucky in your simulation,
if you stick in simulation with free software, maybe you want to use other free software such as salome, netgen, gmsh and like that for your simulation and import it to OpenFOAM
Old   June 4, 2013, 05:41
s.m
saeideh mohamadi
you mean what is happen after running extrudeMesh is because of my mesh?
Old   June 4, 2013, 05:48
Nima Samkhaniani
i mean that you can create your mesh some where else with less sophisticated problem
but now, i remember, maybe there is another clue
before, extrude Mesh use following command:
flattenMesh
check whether it helps or not
s.m likes this.
Old   January 29, 2014, 01:53
Mehdi GHOZALI
Dadou is on a distinguished road
dear Saideh in doing this command:
surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil
this error displayed:
Create time
Reading surfaceFeatureExtractDict
cannot open file
file: /home/ehsan/Desktop/airfoil_snappyHexMesh_modified/system/surfaceFeatureExtractDict at line 0.
    in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
ehsan@Ehsan-com:~/Desktop/airfoil_snappyHexMesh_modified$ surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil
Usage: surfaceFeatureExtract [OPTIONS]
options:
  -case <dir>       specify alternate case directory, default is the cwd
  -dict <file>      read control dictionary from specified location
  -noFunctionObjects
                    do not execute functionObjects
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
extract and write surface features to file
Using: OpenFOAM-2.2.0 (see www.OpenFOAM.org)
Build: 2.2.0-b363e8d14789
--> FOAM FATAL ERROR:
Wrong number of arguments, expected 0 found 3
Invalid option: -writeObj
Invalid option: -includedAngle
FOAM exiting
I'm totally unfamiliar with snappyHexMesh commands if I have run it mistakenly.
Did you solve this problem? Because I have the same problem and I can't solve it. I tried to look it up in the forum but nothing new or really helpfull.
Thank you
Dadou
Dadou is offline   Reply With Quote
Old   January 29, 2014, 02:30
Nima Samkhaniani
well, you may want to add surfaceFeatureExtractDict to your system folder, and edit it appropriately
Old   January 29, 2014, 03:14
Mehdi GHOZALI
Thank you
Regards,
[mesh manipulation] extrudeMesh from STL Surface TRT OpenFOAM Meshing & Mesh Conversion 1 March 26, 2018 07:15
[mesh manipulation] Generating 3-D axisymmetric mesh using extrudeMesh martyn88 OpenFOAM Meshing & Mesh Conversion 17 June 21, 2017 19:42
extrudeMesh - odd behaviour grjmell OpenFOAM 0 September 20, 2011 08:41
extrudeMesh from patch Lodda OpenFOAM 4 August 15, 2011 10:35
BIG Problem in extrudeMesh! wind_fyp OpenFOAM 0 January 28, 2010 00:41
