convergence problem / bluff body / k omega
Old   June 14, 2013, 07:43
Default convergence problem / bluff body / k omega
Luca
LM4112 is on a distinguished road
Dear all
I am trying to simulate the steady state flow around a bluff body in a wind tunnel using RANS k-omega turbulence model. I have attached the code and some pictures.
The problem is that the simulation doesn't converge (after roughly 2000 steps the residuals jump). I have tried to lower the relaxation factors without success. Furthermore the stagnation Cp on the nose is 1.8 instead of 1. It is strange as the simulation fits very well the wind tunnel data o the rest of the body.
Can anybody help me please? thanks a lot
best regards
Luca
LM4112 is offline   Reply With Quote
Old   June 15, 2013, 15:52
Luca
bump..nobody can help me?
Old   June 15, 2013, 17:55
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
My experience with k-omega SST is that the quality of the residuals is very much related to how "good" your mesh is. Regardless of that, the residuals are usually pretty bad. I am guessing that the highest one in your picture is for pressure. If you run the motorbike tutorial from simpleFoam tutorial directory, you will see that it also has pretty poor residuals.
Somebody has to have the ahmed body in SST k-omega. Maybe ask the author of the discretizer; he has an example with the Ahmed body using Discretizer.
Did you use SnappyHexMesh? If so, can you include the blockMesh, STLs, and snappyHexMesh files. The first opportunity to improve the quality is likely in those files.
JR22 is offline   Reply With Quote
Old   June 16, 2013, 06:28
Luca
I have managed to solve the problem using a higher omega at the inlet. Thank you anyway for the reply
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
[ANSYS Meshing] Simple Symmetry Mesh Question - Flow around Bluff Body Matlab69 ANSYS Meshing & Geometry 20 April 23, 2012 09:55
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
Convergence problem suthichock Main CFD Forum 27 May 11, 2009 07:05
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
