July 15, 2013, 05:27 |
Scaling and SnappyHexMesh
Aditya
Hello
I am trying to do a blower simulation. I have a working simulation. But while checking throught the log files I found that I have "did not succesfully snap mesh. Giving up" statement at the end of snappyHexMesh. So I searched some thing and some one suggested that we have to scale the mesh to correct units before doing snappyHexMesh. I did it. Now the problem is when I scale the mesh before snappyHexMesh, Some of the patches which should have faces on them are shown as empty and are removed by "createPatch" utility. I am confused what I am doing wrong. Do I also have to change the base mesh. ?? Here is the outline of the sequence of operations I perform before solving : PHP Code:
or is there any other reason for getting this "did not succesfully snap mesh. Giving up" problem...?? Thanks in advance |
July 15, 2013, 06:21 |
#2 | ||
Rep Power: 18 |
Dear kingmaker,
both the background mesh from blockMesh as well as the stl file have to have the same scale. So in order to do so you should scale the mesh before the domain and stl file are decomposed, so the correct order of your workflow should look like follows: Quote:
It looks to me like you are trying to refine the mesh in certain regions, but are missing the refineMesh command, am I right? I hope I could contribute regards |
July 15, 2013, 07:40 |
Aditya
Hello colinB
Thank you for your reply. I will try this and post the result. Also about topoSet, I just do some patch merges and invertions in topoSet to make things easy. I am not doing any refinement there. So is it also necessary to do "refineMesh" command after that.. ?? |
July 15, 2013, 09:05 |
Rep Power: 18 |
Hi
concerning topoSet: I understand topoSet as a selection tool to pick certain cells in a region and therefore I would expect a manipulation command right afterwards like the refineMesh command (this is what I use it for). So if you don't want to refine anything you don't have to use the command here of course. However I don't have a clue how to perform mesh merges and inversions so I can not tell you whether the command is placed properly here and whether it is maybe the source of your error message. regards |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] stl and snappyHexMesh dimensions mismatch | romant | OpenFOAM Meshing & Mesh Conversion | 11 | May 4, 2015 09:44 |
[snappyHexMesh] What is this in snappyHexMesh ? | andrea.pasquali | OpenFOAM Meshing & Mesh Conversion | 5 | November 8, 2011 11:28 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
motorBike tutorial and Scaling - New geometry used, scaled and now large velocity!!! | scott | OpenFOAM | 1 | July 29, 2010 04:09 |
