July 31, 2013, 11:08 |
porous simulation
Yuri Frey
Rep Power: 12 |
Hi everyone!
I spent a few days trying to understand how to set up with OF a case which is unsteady, incompressible and laminar flow with a porous medium, but I still have some troubles. First of all I don't know what solver should I use: - icoFoam? (from the user guide it seems unable to treat porosity) - porousSimpleFoam? (it is possible to set laminar? if I put Euler in ddtSchemes does it solve unsteady?) Second, I made my mesh in Gambit dividing the domain into 2 zones, but when I transform the mesh to OF I don't know how to specify that one of them is a porous medium and to set a Darcy law (in "cellZone" I only have Code:
FoamFile { version 2.0; format ascii; class regIOobject; location "constant/polyMesh"; object cellZones; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 0 () // ************************************************************************* // I am very confused and any help would be very appreciated.. Thank you very much! Yuri |
July 31, 2013, 13:41 |
Lieven
Rep Power: 22 |
Hi Yuri,
If you are working with OF 2.2.x Have a look at the pimpleFoam solver in combination with the fvOptions. That should make it possible to combine porosity with transient simulations. You should not do transient simulations with the simple algorithm. The algorithm requires under-relaxation and this is in conflict with proper time integration. If you have an older version of OF, I'm afraid you will be forced to write your own solver (of course you can do some copy-pasting from this existing ones). The fact that you have laminar flow is easily accounted for by setting the turbulenceModel to 'laminar'. Cheers, L |
August 1, 2013, 05:54 |
Yuri Frey
Rep Power: 12 |
Hi Lieven,
thank you very much for your answer. I am using OpenFOAM 2.2.1 so I will try to follow your advice. But I still have the problem of separating cell zones. In Gambit I have two different zones but when I convert the mesh I lose this information. Do you have any idea of what should I do? Is OF supposed to recognize the zones or should I modify something in cellZones? Thank you again! Yuri |
August 1, 2013, 06:19 |
Lieven
Rep Power: 22 |
Hi Yuri,
I have no experience in working with Gambit in combination with OpenFOAM so I can't really help you with that. I would not start messing around in cellZones (I think you will get lost in its complexity). Maybe Gambit has other options available for identifying cells (cause that's in fact what you are doing) besides defining a 'zone' which are recognized by OF. Good luck! Lieven |
August 2, 2013, 08:31 |
Yuri Frey
Rep Power: 12 |
Thank you anyway Lieven, you've been very helpful. I'm going to try asking in a specific thread in the meshing section.
Yuri |
August 4, 2013, 18:02 |
Yuri Frey
Rep Power: 12 |
Hi Lieven!
I solved the meshing problem but I still need a little help for the fvOptions part.. These are the first lines of my cellZones file: Code:
FoamFile { version 2.0; format ascii; class regIOobject; location "constant/polyMesh"; object cellZones; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2 ( zone2 { type cellZone; cellLabels List<label> 500 ( 0 1 Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvOptions; } porosity { type explicitPorositySource; active yes; selectionMode cellZone; cellZone zone2; explicitPorositySourceCoeffs { type DarcyForchheimer; DarcyForchheimerCoeffs { d d [0 -2 0 0 0 0 0] (5e7 -1000 -1000); f f [0 -1 0 0 0 0 0] (0 0 0); coordinateSystem { e1 (1 0 0); e2 (0 1 0); } } } } Thank you again for your help, Yuri |
August 4, 2013, 18:19 |
Lieven
Rep Power: 22 |
Hi Yuri,
I'm sorry to say that I can't help you with this. I'm still using version 2.1.x which doesn't use the fvOptions thing. So I hope someone else can assist you in setting this up properly. Cheers, L |
August 5, 2013, 04:40 |
Yuri Frey
Rep Power: 12 |
Thank you Lieven, I will try again in a specific thread.
Yuri |
fluent 2D axisymmetric with swirl simulation with porous media | user0314 | FLUENT | 1 | June 11, 2015 02:57 |
Porous Region within Open Air "Wind Tunnel" Region Interfacing | pkirchner | STAR-CCM+ | 10 | March 27, 2014 19:10 |
porous medium simulation in openfoam | subhsngh | OpenFOAM Running, Solving & CFD | 0 | June 26, 2013 08:04 |
simplified paralle tube bundle simulation (porous domain) | Benfa | CFX | 1 | May 5, 2013 08:01 |
Simulation of incompressible flow in porous medium | Jack | Main CFD Forum | 7 | February 16, 2000 11:27 |
