Launder Shrma Low Reynolds turbulence model case setup
Like Tree3Likes
  • 3 Post By sivakumar
Old   August 29, 2013, 06:11
Default Launder Shrma Low Reynolds turbulence model case setup
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
I am running a simulation with low Re turbulence model, I have checked the mesh, it is fine, there is no problem in it.
I came up with successful case setup for kOmegaSST. It is working fine, but the results are deviating.
So now I want to do the simulation with LaunderSharmaKE model, for that I am trying many different settings but none of them is working.
I know that we no need to give any wall function for lowRe model, so I have given fixedValues for that.
The BC's are as follows for SimpleFoam, Please have a look and help me.
0/k:
internalField uniform 0.39;
boundaryField
inlet
type fixedValue;
value uniform 0.39;
outlet
type zeroGradient;
top0 // wall
type fixedValue;
value uniform 1e-12;
0/epsilon:
inlet
type fixedValue;
value uniform 0.26295;
outlet
type zeroGradient;
top0 // wall
type fixedValue;
value uniform 1e-10;
0/nut:
internalField uniform 0;
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
top0 // wall
type nutLowReWallFunction;
value uniform 0;
0/p:
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
top0 // wall
type zeroGradient;
0/U:
internalField uniform (0 0 0);
boundaryField
outlet
type zeroGradient;
inlet
type flowRateInletVelocity;
flowRate 2; // Volumetric/mass flow rate [m3/s or kg/s]
value uniform (0 0 0); // placeholder
top0 //wall
type fixedValue;
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   September 5, 2013, 11:34
sivakumar selvaraju
Hi there,
Still I am not winning, some one please help me.
I have done small change according to OpenFOAM training manual.
for Wall,
nut ----> fixedValue 0
k ------> fixedValue 0 (1e-12)
epsilon ->zeroGradient but I have given small fixedValue (1e-10)
k is always bounding for the above setting.
I dont understand what is the problem, please help me.
Thanks,
Sivakumar
Old   September 5, 2013, 13:18
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
I set up a case for buoyantBousinesqPimpleFoam and your turbulent model using HelyxOS. Setup a test case with a simple geometry and try using the BC's they setup. For me it worked at that time.
JR22 is offline   Reply With Quote
Old   September 14, 2013, 08:20
sivakumar selvaraju
Hi there,
I am happy to give you this information, the case setup for low Re model is successful. my problem was Y+ value, it was 1 or less, according the available information it is correct, but it is not at all working with Y+ of 1 or less. So I changed the Y+ value 3 -5, it is working fine. I hope I will get the good result.
Regarding the wall function,
low Re model wall function no need and
high Re model yes wall function need.
Low Re model:
turbulence model : LaunderSharmaKE
nut ----> fixedValue (0)
k -----> fixedValue (1e-12)
epsilon -----> fixedValue (1e-8) it can be zeroGradient as well
nuTilda -----> fixedValue (0)
for high Re model:
nut ----> nutkWallFunction value (0)
k -------> kqRWallFunction value uniform (*******)
epsilon ----> epsilonWallFunction value uniform (*******)
nuTilda -----> zeroGradient
I hope it will be useful.
Thanks,
Sivakumar
thiagopl, beatlejuice and lpz456 like this.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 10:48
Launder & Sharma model in combusion case Richard Carroni Main CFD Forum 1 November 17, 1998 18:59
