surfaceTransformPoints [OPTIONS] <surfaceFile> <output surfaceFile>
Like Tree2Likes
  • 1 Post By fumiya
  • 1 Post By zhengzh5
Old   October 12, 2013, 02:42
Default surfaceTransformPoints [OPTIONS] <surfaceFile> <output surfaceFile>
s.m
saeideh mohamadi
s.m is on a distinguished road
Hi
whould you please tell me, how could i use surfaceTransformPoints in openFoam, i use the surfaceTransformPoints -help and i get the fowlloing instruction:
i write for its option -yawPitchRoll '(-7.05 0 0)'
now i don't know what should i write for <surfaceFile> & <output surfaceFile> ?
Please give me some guidance
Thank you very much.
s.m is offline   Reply With Quote
Old   October 12, 2013, 10:39
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You might want to read the following thread:
http://www.cfd-online.com/Forums/ope...ts-rotate.html
Hope this helps,
Fumiya
s.m likes this.
fumiya is offline   Reply With Quote
Old   October 15, 2013, 13:37
Jace
zhengzh5 is on a distinguished road
Originally Posted by s.m View Post
Hi
surfaceTransformPoints is for when you want to transform a .stl file (hence you need an input and output surface files). If you already have the mesh and will like to do the transformation on it, use transformPoints instead. And the arguments you supplied should be sufficient.
s.m likes this.
zhengzh5 is offline   Reply With Quote
