[swak4Foam] groovybc and heat flux on wall
Like Tree1Likes
  • 1 Post By gschaider
Old   October 5, 2013, 08:39
Default groovybc and heat flux on wall
mohsen kh
m5m5kh is on a distinguished road
Hi foamers
I used groovyBC as boundary condition for wall of my case.but I have a problem.I modifed the heat flux on the wall but when temperature of the upper region of furnace is still 298K and the outer temperature is 298K too.so I expected to see zero gradient on the wall but there is a flux in paraFoam
it show me temprature at walls 0 while the lowest temperature is 298 in my boundary conditions.
I attached my case figure.
any help would be appreciated.
type groovyBc;
variables "h=1.12;k=0.065;Tinf=298;";
gradientExpression "h/k*(T-Tinf)";
fractionExprssion "0"; // 0 for neumann boundary condition
value uniform 298;
regards
Mohsen
m5m5kh is offline   Reply With Quote
Old   October 6, 2013, 00:46
Unhappy
mohsen kh
no idea!!!!!!!!!!
Old   October 6, 2013, 10:16
Assistant Moderator
Bernhard Gschaider
Originally Posted by m5m5kh View Post
Hi foamers
type groovyBc;
value uniform 298;
regards
Mohsen
a) you have a typo in fractionExpression
b) Paraview doesn't know anything about groovyBC so the values it displays on the boundary might be wrong
c) for finding problems always use the Cell-values in Paraview. The point values are something it interpolates from the real values and might as well be a problem of Paraview
mgg likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 6, 2013, 10:19
Assistant Moderator
Bernhard Gschaider
no idea!!!!!!!!!!
I think it is a bit strange to expect an immediate answer
a) because this is a voluntary community service
b) it is a weekend
Old   October 6, 2013, 11:30
Talking
mohsen kh
Hi Bernhard
I'm sorry for ruining your weekend you are right
apologies
regards
Mohsen
[swak4Foam] Fixed Wall Heat Flux with groovyBC flowpow OpenFOAM Community Contributions 0 September 7, 2016 09:48
[swak4Foam] Varying heat flux using groovyBC with chtMultiRegionSimpleFoam hcl734 OpenFOAM Community Contributions 5 December 15, 2015 08:55
[swak4Foam] groovybc and heat flux on wall m5m5kh OpenFOAM Community Contributions 3 October 3, 2013 14:19
[swak4Foam] Wall heat transfer using groovyBC (XiFoam solver) usergk OpenFOAM Community Contributions 7 February 4, 2011 13:36
groovyBC nonuniform Wall heat flux Shoonya Main CFD Forum 0 August 11, 2010 13:03
