BC
Old   October 20, 2013, 23:48
Default BC
mohsen kh
m5m5kh is on a distinguished road
Hi dear foamers
I have a problem I have a porous sphere which was located in a porous domain. I have some problems
1. what condition should I use for the surface of sphere?
2. how should I define the porous domain while I used sphereToCell in topoSetDict for defining the sphere az a porous zone.
I meshed my case in gambit.
see the attached picture.
any help would be greatly appreciated.
Mohsen
m5m5kh is offline   Reply With Quote
Old   October 21, 2013, 06:11
Nima Samkhaniani
nimasam is on a distinguished road
which solver do you use?
if you are using *porous*solver in OpenFOAM, then you need just define your zone in topoSet, then appropriate source term will be applied in conservative Eq.s and no specific BC needed.
To find out how to create a zone look at following tutorials:
./lagrangian/reactingParcelFilmFoam/splashPanel/system/wallFilmRegion.topoSet
./lagrangian/reactingParcelFilmFoam/splashPanel/system/wallFilmRegion/createWallFilmRegionPatches.topoSet
./lagrangian/reactingParcelFilmFoam/hotBoxes/system/topoSetDict
./lagrangian/reactingParcelFilmFoam/cylinder/system/topoSetDict
./lagrangian/reactingParcelFilmFoam/rivuletPanel/system/wallFilmRegion.topoSet
./lagrangian/coalChemistryFoam/simplifiedSiwek/system/topoSetDict
./lagrangian/reactingParcelFoam/filter/system/topoSetDict
./mesh/moveDynamicMesh/simpleHarmonicMotion/system/topoSetDict
./multiphase/MRFMultiphaseInterFoam/mixerVessel2D/system/topoSetDict
./multiphase/twoPhaseEulerFoam/mixerVessel2D/system/topoSetDict
./multiphase/interDyMFoam/ras/damBreakWithObstacle/system/topoSetDict
./multiphase/interDyMFoam/ras/floatingObject/system/topoSetDict
./multiphase/MRFInterFoam/mixerVessel2D/system/topoSetDict
./multiphase/interFoam/ras/damBreakPorousBaffle/system/topoSetDict
./multiphase/interFoam/les/nozzleFlow2D/system/topoSetDict.2
./multiphase/interFoam/les/nozzleFlow2D/system/topoSetDict.1
./multiphase/compressibleTwoPhaseEulerFoam/mixerVessel2D/system/topoSetDict
./multiphase/cavitatingFoam/ras/throttle/system/topoSetDict.3
./multiphase/cavitatingFoam/ras/throttle/system/topoSetDict.2
./multiphase/cavitatingFoam/ras/throttle/system/topoSetDict.1
./multiphase/cavitatingFoam/les/throttle3D/system/topoSetDict.3
./multiphase/cavitatingFoam/les/throttle3D/system/topoSetDict.2
./multiphase/cavitatingFoam/les/throttle3D/system/topoSetDict.1
./multiphase/cavitatingFoam/les/throttle/system/topoSetDict.3
./multiphase/cavitatingFoam/les/throttle/system/topoSetDict.2
./multiphase/cavitatingFoam/les/throttle/system/topoSetDict.1
./multiphase/multiphaseEulerFoam/mixerVessel2D/system/topoSetDict
./combustion/PDRFoam/flamePropagationWithObstacles/system/topoSetDict
./combustion/fireFoam/les/smallPoolFire3D/system/topoSetDict
./combustion/fireFoam/les/oppositeBurningPanels/f.topoSetDict
./combustion/fireFoam/les/oppositeBurningPanels/fBurner.topoSetDict
./combustion/fireFoam/les/oppositeBurningPanels/cRefine.topoSetDict
./combustion/fireFoam/les/smallPoolFire2D/system/topoSetDict
./incompressible/pimpleDyMFoam/mixerVesselAMI2D/system/topoSetDict
./incompressible/pimpleDyMFoam/propeller/system/createInletOutletSets.topoSetDict
./incompressible/pimpleDyMFoam/propeller/system/removeRedundantZones.topoSetDict
./incompressible/pimpleDyMFoam/propeller/system/createAMIFaces.topoSetDict
./incompressible/simpleFoam/turbineSiting/system/topoSetDict
./incompressible/simpleFoam/pipeCyclic/system/topoSetDict
./incompressible/pimpleFoam/TJunctionFan/system/topoSetDict
./incompressible/pimpleFoam/elipsekkLOmega/system/topoSetDict
./incompressible/potentialFreeSurfaceFoam/oscillatingBox/system/topoSetDict
./heatTransfer/chtMultiRegionSimpleFoam/heatExchanger/system/air/topoSetDict.2
./heatTransfer/chtMultiRegionSimpleFoam/heatExchanger/system/air/topoSetDict.1
./heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeater/system/topoSetDict
./heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeaterRadiation/system/topoSetDict
./heatTransfer/buoyantSimpleFoam/circuitBoardCooling/system/topoSetDict
./heatTransfer/chtMultiRegionFoam/multiRegionHeater/system/topoSetDict
./heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater/system/topoSetDict
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
