mergeMesh error!!
Old   December 14, 2013, 08:41
Default mergeMesh error!!
Ye Zhang
kiddmax is on a distinguished road
Dear foamers
I have two separate domains which are to be merged together. But the errors shows below:
Master:      "kklomega_Ogrid_chord100_402x141x2"  region region0
mesh to add: "kklomega_Ogrid_chord100_402x141x2_tunnel"  region region0
Create Times
Reading master mesh for time = 0
Create mesh
Reading mesh to add for time = 0
Create mesh
Writing combined mesh to 1
patch names:
9
upper
du
transition
riso
interface_b
inlet
outlet
tunnel_wall
interface_t
patch types:
9
wall
wall
wall
wall
patch
patch
patch
wall
patch
point zone names:
0
face zone names:
2
int_FLUID_BLADE
int_FLUID_T
cell zone names:
2
fluid_b
fluid_t
Copying old patches
Adding new patches.
--> FOAM FATAL ERROR:
Illegal zoneID 1 for face 1622524
    From function resetZones(const polyMesh&, polyMesh&, labelListList&labelListList&, labelListList&)
    in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 1651.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::polyTopoChange::resetZones(Foam::polyMesh const&, Foam::polyMesh&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<int> >&) const in "/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#3  Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in "/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
 in "/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/mergeMeshes"
#6  __libc_start_main in "/lib64/libc.so.6"
 at /usr/src/packages/BUILD/glibc-2.11.1/csu/../sysdeps/x86_64/elf/start.S:116
I am using OF2.1.0. Do you have some ideas to solve this problem? Thanks a lot!
Best regards,
Ye
kiddmax is offline   Reply With Quote
Old   December 16, 2013, 06:15
Philip Brown
Phizz82 is on a distinguished road
Hi Ye.
I'm not entirely sure of the problem but the error message seems to be looking for a zone 1 but further up in the code this doesn't seem to have been defined (I can see zone 0 and zone 2 defined). Does this help?
Phizz82 is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
