non uniform initial conditions
Old   February 19, 2014, 14:09
Default non uniform initial conditions
ajnewman is on a distinguished road
Hello all,
Simple (?) question: If I want to specify a nonuniform initial condition using the internalField nonuniform List<vector> approach, like in the boxTurb tutorial, do I specify my initial velocity at all the points listed in the "points" file and in that order? That is, if the first entry in points is (0,0,0) should the first entry in U be the velocity at (0,0,0)? This simulation has multiple blocks.
I have seen the setFields as used in the dam break tutorial but am not currently savvy enough to use this to do what I want.
The background is I am attempting to run a simulation in OpenFOAM starting with an initial condition generated by a fortran code on a mesh that is not the same as my OpenFOAM mesh.
Any input is appreciated.
-Jensen
ajnewman is offline   Reply With Quote
Old   February 19, 2014, 14:49
I think I answered a bit of my own question since the points file has (no_cells_x+1)*(no_cells_y+1)*(no_cells_z+1) entries whereas a nonuniform velocity entry should have only (no_cells_x)*(no_cells_y)*(no_cells_z) entries. Based on this I am guessing that velocity needs to be spec'd at cell centers.
Old   February 19, 2014, 17:03
Jace
zhengzh5 is on a distinguished road
you're right on. it's finite-volume approach. So all volScalarFields/volVectorFields are specified at the cell-center. Surface and point values are usually interpolated based on cell-center values.
zhengzh5 is offline   Reply With Quote
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 12:12
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
Extremely slow simulation with interDyMFoam jrrygg OpenFOAM Running, Solving & CFD 9 April 23, 2013 10:14
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
