outlet boundary condition for open environment |
March 1, 2014, 22:08 |
Prasad
Rep Power: 12 |
Dear all,
I am trying to simulate current flow in a tank with open environment at the outlet. I have tried several ways only to find that the current is reflected at the outlet causing water level to rise in the tank. I am running a simple case where current is generated at the inlet using waves2foam. I would like to simulate an open environment for my outlet boundary condition. But I find that the current flow does not leave the tank but is reflected. Is there something wrong with my outlet boundary conditions ? These are my boundary conditions for the outlet alpha1: type zeroGradient p_rgh : type buoyantPressure value uniform 0 U: type inletOutlet; inletValue uniform (0 0 0); value $internalField; *internal Field was set to uniform (0 0 0) I would also like to ask does setting potential current (0 0 0) in the wave properties file for the outlet absorb current generated at the inlet? Thank you. Regards, Prasad Last edited by wyldckat; March 2, 2014 at 04:04. Reason: Double posting |
March 2, 2014, 03:49 |
Prasad
Rep Power: 12 |
Hi all,
With regards to my earlier query, attached are the sectional views for alpha1 and U. The current flow for the inlet which is at the left is 2 ms-1. Thank you. Regards, Prasad |
Outlet boundary condition for a heated tube flow | JinBiao | OpenFOAM Running, Solving & CFD | 0 | July 28, 2012 03:56 |
pressure outlet boundary condition | liladhar | STAR-CCM+ | 6 | May 12, 2012 05:09 |
Boundary Condition outlet | natantyt | FLUENT | 0 | September 27, 2010 15:30 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Outlet boundary condition | Asghari | Main CFD Forum | 0 | May 5, 2006 16:51 |
