Setting up an initial velocity field for scalarTransportFoam |
May 10, 2014, 08:31 |
Marco Langiu
Hello everyone,
I am new to OpenFOAM and therefore have some trouble getting a start on it, since I cannot find tutorials on what I'm looking for. My aim is to simulate the mass transfer of oxygen in a falling flat film of water. To do this I decided to use the scalarTransportFoam solver which looked promising after I did the tutorial for the pitzDaily case. However, I cannot find any documentation of how to set up the required velocity field without punching in the desired values for each cell by hand. I've attempted to create a steady field by running a simulation using the interFoam solver, but the solving process failed due to numerical reasons I don't understand. For a start I want to simulate my case in 2D with a steady velocity profile which should look like this: u(y) = g*h^2/nu*(y/h-.5*(y/h)^2) Where h=10mm is the height of the film, which for now is assumed to be constant in the x (=flow) -direction. My geometry is a simple, one block mesh of 50x10x1 mm with (100 10 1) cells. Is there any simple way to implement this? Do you have literature/tutorial suggestions? I don't mean to bother you with these fundamental problems, but I searched for two days now and couldn't find anything that brought me any further. Thank you for your help! |
generate, how to, initialize, set up, velocity field |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
