May 5, 2014, 17:30 |
scotch decomposition is crashing my mesh
robo
Rep Power: 13 |
I'm working on an external flow that I'm running in simpleFoam at the moment trying to get a steady state solution. The mesh is around 2 million cells; developed using snappyHexMesh. It passes all mesh checks, and I've run it in serial for around 100 steps with no problems. When I decompose it using scotch decomposition in decomposePar, if I use more then 2 processors, it will crash on the first step, claiming that the U matrix is singular. If I use a simple decomposition, it runs fine.
I would like to be using more processors then I can easily develop a simple decomposition for, however clearly something is wrong with scotch/decomposePar and I am not sure how to debug it. Has anyone run into similar issues? Any advice on using the scotch decomposition? Is metis more reliable? I'm using OF 2.3.0 if that's relevant. |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
OpenFOAM Scotch Decomposition: Version and Reference | dancfd | OpenFOAM Pre-Processing | 4 | April 16, 2014 21:40 |
interFoam & decomposition method: scotch | MacGyver | OpenFOAM Running, Solving & CFD | 2 | May 23, 2012 07:00 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
