Phase dependant boundary condition
Old   May 12, 2014, 11:05
Default Phase dependant boundary condition
Peter
John Degenkolb is on a distinguished road
Hi all,
I’m running a transient two-phase flow simulation through a porous medium using the porousInterFoam solver.
Now, I would like to use a boundary condition, with the following properties:
It should be permeable for phase 1 (air), but impermeable for phase 2 (water). An effect like this is known form GoreTex membranes in outdoor clothes.
The porousInterFoam solver calculates the volume fractions of the two phases for every cell. So, as soon this volume fraction passes a value of 0.5 in a cell which is in contact to the boundary, the condition should switch.
For the permeable (not-wall) case I would like to implement a constant pressure condition.
The question is:
Is there a boundary condition capable to do this by default? And if not: Which is the closest existing boundary condition that I could use a basement for programming?
Thank you in advance for any hints and advices to improve my question!
Peter
John Degenkolb is offline   Reply With Quote
Old   May 13, 2014, 09:22
Nima Samkhaniani
nimasam is on a distinguished road
i dont know such BC, but a general advice can be use of groovyBC from third party packahe swak4Foam
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 3, 2014, 11:14
Default groovyBC for switchable BC based on phase fraction
Peter
Ok, thanks for the reply.
So here I am trying to use groovy BC for the above mentioned problem.
In my 0/U file I've got:
upperWall
type groovyBC;
value Expression "0";
variables "alphaMatrix{upperWall}=alpha1;"
(Yes, I'm trying to access values on the same, not on a different patch. I hope it works...)
The error I get is:
Parser Error for driver PatchValueExpressionDriver at "1.1-5": "field alpha1 not existing or of wrong type"
"alpha1"
I also tried with
alphaMatrix{upperWall}=alpha,
alphaMatrix{upperWall}=alpha.water,
alphaMatrix{upperWall}=alpha.matrix,
alphaMatrix{upperWall}=alphawater.
However, it doesn't seem to find the alpha scalarfield.
The input file specifying the initial volume fractions is called alphamatrix:
FoamFile
   version 2.0;
    format ascii;
    class volScalarField;
    object alpha.water;
Is it possible to access it in groovyBC?
Thank you in advance!
Peter
Boundary condition at phase interface skp OpenFOAM Programming & Development 5 February 12, 2017 20:51
conjugate boundary condition Daniel_Khazaei OpenFOAM Programming & Development 0 December 31, 2013 13:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 03:11
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
